89 LX wont start without starter fluid
Ok I got a 89 LX with 88 GT drivetrain ecu,trans,engine ect.
here is the deal it wont start on its on...i put a new regulator and fuel pump(155lph) on it and it doesnt hold fuel in the line when I press the shrader valve nothing....
I also changed the injectors....any Ideas?
Your fuel filter wud have to be pretty clogged to allow that to happen, but change it anyway. Can you hear the fuel pump run? If so, check for a collapse fuel line or a frozen line. And make sure no one has put anything in your tank.......
ok new fuel filter all lines were replaced with rubber fuel lines due to rust...yes i can hear the fuel pump and no one put anything in the tank i replaced the stock one because i thought that might have been the problem but it still does it
