SVT Forums
brakes????
Old Oct 3, 2006 | 06:44 PM
freewilly's Avatar
freewilly
I ♥ Acer
Default RE: brakes????
i buy ford brand pads only. great braking , they made by dammit a 3 letter word? brp's pbr's maybe?the ford pads have the pins and clips in the box. did your's?
Old Oct 3, 2006 | 08:28 PM
CobraSnake's Avatar
CobraSnake
ORIGINAL: freewilly
Nope
Old Oct 4, 2006 | 01:23 AM
7arpad7's Avatar
7arpad7
Man, I am not going to be much help here... I had the same problem after replacing the pads on my 97 (dang it if everything didn't look just fine down there after the install), so then I got despirate and took it to Ford. They told me that I needed new front rotors and pads (that is the kicker, the pads were new)... so I bought some via the aftermarket and had them install them (I hope that it pissed them off that I didn't go with stock Ford parts)... Now she stops on a dime and doesn't make any noise... sounds like Ford has some kind of secret bull shize going on here... I would love to hear what you come up with on the fix for yours... I am feeling like I got jacked!
Old Oct 4, 2006 | 05:00 AM
hulian's Avatar
hulian
i did the brakes on my 99 cobra a few weeks ago and put on the bear decela rotors(slotted and cross drilled) and PFC performance friction pads(standard pad is just a regular semi metalic) on. the new pads came with the pad clips but not the pins most brakes you buy will not come with the new pins just the clips. I am a manager at AutoZone and i got it all though there. for some reason the rear pads were harder to get a hold of. the ones for a gt are identical but they are a thicker pad witch will not work. so i got those somewere else.
the noise could becaused by a bent or loose or missing pad clip, if those were not put back on that would let your brake pads move arounfd just enouph to make noise and rattle. you should be able to pick up disc brake hardware kit with the new clips in it. they are easy to put on. also make sure everything is tight and it just isn't something coming loose.
Brake Disc Hardware Kit for a
1999 Ford Mustang Cobra
Front (Change)
Normal Stock
Item Part
No.
BRAKEWARE H5800 $7.99 this is off AUTOZONE.com
Brake Caliper Bolt/Pin for a
Item Part
No.
BRAKEWARE H15009 3 MO $6.99
hope this will help. like i said i just did these a few weeks ago so my mind is still fresh, anything else just let me know.
Old Oct 4, 2006 | 02:04 PM
svt99redcobra's Avatar
svt99redcobra
yea that helps me alot.....is it me or do the pads were out a little faster on a cobra. Maybe cause were always going fast. lol my brakes started squeeking a few days ago but the pads are still thick. I dunno. Anyway im swinging by autozone to pick up the set you mentioned because i have some zipties on it now(jerry rigging) and they are not holding up as well as i need.
Old Oct 4, 2006 | 05:40 PM
CobraSnake's Avatar
CobraSnake
awesome thanks for the advice. I'm going to be going to my buddies shop tomorrow to see what he can do.
Old Oct 4, 2006 | 10:25 PM
michael12203's Avatar
michael12203
when i replaced mine i noticed these clips go behind the brakes and keep them from moving around i did not put one on one side and it made a rattling, i realized that i left it out and put it in and it stopped. that might be the problem
Old Oct 5, 2006 | 05:44 PM
CobraSnake's Avatar
CobraSnake
ORIGINAL: hulian
Front (Change)
Normal Stock
Item Part
No.
Item Part
No.
i believe this was the problem. Went to an autozone type store and bought two sets of front brake hardware. It came with these clip things that take up space between the claiper and the claiper housing. They were rattling together. Fixed the problem and they don't rattle one bit. Thanks for all the help guys. It was a S looking clip that hooked right on the claiper.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
