SVT Forums
Lowering Question
Old Apr 17, 2008 | 10:55 PM
QuarterMileMaster's Avatar
QuarterMileMaster
Default Lowering Question
So... I know pretty much about engines, but when it comes to suspension I'm basically lost.
I want to drop my Cobra, especially in the front, because it's currently got the 4x4 stance and itdoesn't look good. Can I just put on lowering springs, or do I need to buy all new suspension to do it correctly? What would be the bad side effects of just installing lowering springs??
Thanks
Old Apr 17, 2008 | 11:21 PM
AZ SNAKE's Avatar
AZ SNAKE
Default RE: Lowering Question
Springs will be fine, you may want to get a pair of Caster Camber plates so it can be aligned better but they are not a must, just a nice to have.
Old Apr 18, 2008 | 08:48 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
^Agreed
Or, go all-in and send that puppy out to Griggs Racing for a GR-40 set-up and I will take you for a run on the Pacific Coast HWY 1 twisties [8D]. You would be amazed how nice your car will handle on a nice coil-over set-up [sm=drlove.gif]
Jazzer........always apimpin'
Old Apr 18, 2008 | 01:19 PM
jlg32281's Avatar
jlg32281
All depends on your budget. Coil overs are best, but a simple upgrade like I have will make a world of difference. I went w/ ford racing B springs, poly isolators, tokico blue shocks and struts. It's a cheap and very effective upgrade. I bought through stangsuspensions.com and they were great. It cost me around $520 to my front door.
Old Apr 19, 2008 | 01:00 AM
AZ SNAKE's Avatar
AZ SNAKE
I now have a coil over set up on the front with Roush stage 3 springs on the rear with a solid axle. Went with Tokico D-specs all the way around. Couldnt imagine what a 4 corner coil over set up would handle like.....
Old Apr 19, 2008 | 08:19 AM
Jazzer The Cat
Retired Moderator
ORIGINAL: AZ SNAKE
It is insane! Complete Griggs GR-40system with full-frame support (upper and lower). 100% of the suspension has been replaced (except rear sway bar). There is only oneset of eurothane bushings on axle-end of lower control arms (UCA have been removed), all other joints are Hiem. Ride is comfortable (equivalent to Saleen), but feel like a spider on center of his web. You can feel every microscopic part of the road....... VERY cool [8D]
Don't wanna hijack, so go to Griggs and read up on it. I run down Z06 Corvettes, BMW's and such all day on twisties. I have yet to tangle with a WRX as those things can be an absolute beast on the back-roads.
Jazzer
Tivo304
Aug 28, 2023 12:19 PM
04stangman
Sep 17, 2015 01:45 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
