SVT Forums
amp light stays on
Old Oct 26, 2003 | 08:27 PM
ryhed's Avatar
ryhed
Default amp light stays on
Last night my amp light came on. I checked the alternator it was bad. I replaced it with the duralast gold. no success. still gives a 12v reading at the battery and light remains on. I have heard that the battery will not charge if the red green to guage wire ( 904 wire) to the guage cluster is not connected properly or at all. what can be done to fix this if it is so. Also is there an external regulator? it's an 87 with a 93 cobra conversion. Any ideas I would appreciate.</P>
</P>
Ryan</P>
Old Oct 26, 2003 | 09:25 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
No external regulator. You should have approx 14 volts at the battery when the car is running, and 12.5 volts when its not. Be sure to have your battery load tested as well, just because you can get 12 v out of it doesnt mean its putting out the amps.
Old Oct 26, 2003 | 10:35 PM
ryhed's Avatar
ryhed
Also replaced the starter solenoid. no luck. Maybe I have purchased a bad alternator from the store or my wires are bad somewhere around the alt. plug.</P>
I found that the car is an 87 with I believe a 93 cobra 340ci conversion and I believe there may have been some splicing at the alternator plug. Does anyone know for sure if the alt had to be re wired?</P>
jhawkr
Oct 30, 2015 01:55 PM
daytooday
Sep 20, 2015 10:55 AM
Colin Ringle
Sep 15, 2015 09:27 PM
MusicCity615
Sep 12, 2015 07:05 AM
cbird1177711
Sep 3, 2015 08:43 PM
