SVT Forums
Oil separator question
Old Mar 21, 2010 | 08:39 PM
89GT351's Avatar
89GT351
Default Oil separator question
Ok, I just bought oil separator for my 03 Cobra and I have a question about the installation. The PVC hose that runs from PVC valve it goes to the back of the intake splits into two hoses one hose goes to the intake the other one goes somewhere down under the supercharger where does it connect? do all 03-04 cobras have this? where do I connect the oil separator? right after the PVC valve or after the two hoses meet? Please help me
Old Mar 22, 2010 | 12:38 AM
mblgjr's Avatar
mblgjr
This is a rough basic here...
Remove PCV hose where it immediately pushes on the PCV-valve going into the driver's rear valve cover. Place that hose end on the inlet side of your separator filter assembly (note: Look for flow arrow on assembly).
Run hose from outlet side of separator filter; back to the PCV valve.
And yes, the hose routing you have is stock. It runs to the lower intake area "below" the superchargers intercooler core.
This is the same idea (based on you using a similar idea for your separator assy.)...installed on an older 5.0
http://www.mustang50magazine.com/tec...tor/index.html
Old Mar 22, 2010 | 04:34 PM
89GT351's Avatar
89GT351
Ok, thank you this is what I needed to know "It runs to the lower intake area "below" the superchargers intercooler core" I thought that it connected to the engine block somewhere below the supercharger I did not know that it ran to the lower intake. I am knew to 4.6L engines. Thanks again.
Tivo304
Aug 28, 2023 12:19 PM
bjdutch2005
Mar 24, 2017 03:38 AM
04stangman
Sep 17, 2015 01:45 PM
kevsgt
Sep 9, 2015 06:20 AM
