SVT Forums
Quick Pulley Question
Old Nov 6, 2010 | 05:43 PM
Scoutn757's Avatar
Scoutn757
Default Quick Pulley Question
On an 04 Termi with a stock upper and lower right now. If I change the upper to a Metco 2.7"; what size belt would I need?
Old Nov 6, 2010 | 06:16 PM
bbcobra's Avatar
bbcobra
73.5 to 74 inch belt. but you will need a aux idler with that small pulley. in that case you'll need about a 74.5 inch belt. add the other 3 idlers (2 100's and one stock 90mm sizes. you can use a stock size belt (75 inch).
Old Nov 6, 2010 | 07:10 PM
Timspony's Avatar
Timspony
SVT Section Moderator
^^^ That would be correct!!!!
Old Nov 17, 2010 | 08:20 PM
Scoutn757's Avatar
Scoutn757
A local guy has an aux idler for 120 with a 100mm pulley. The same guy I bought the unmarried tuner from. 100mm would be fine? Thanks for the input, sorry for the delayed response!
tmdm
May 2, 2021 02:49 PM
spdeplayer2
Oct 24, 2015 09:45 AM
ctgreddy
Sep 20, 2015 08:35 PM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
