SCT TUNER QUESTION
Old Jun 28, 2006 | 09:05 PM
  #21
03YellowPony's Avatar
03YellowPony
Default RE: SCT TUNER QUESTION
ORIGINAL: bain_bk
i went to the sct website i jsut need to know what to set me shift point, idle, air/fuel, etc to and couldnt find any thing
I can't stress this enough. UNLESS YOU KNOW WHAT YOU ARE DOING, AND HAVE THE PROPER METERS, DO NOT MESS WITH THE AIR/FUEL MIXTURE!!! You can really mess things up to the point of doing serious damage!!!
Old Jun 28, 2006 | 09:06 PM
  #22
03YellowPony
ORIGINAL: bain_bk
yea i need to know what would be good because it still shifts at 5600rpm
I had my shift points at 6250RPM. And I removed the speed limiter all together.
Old Jun 29, 2006 | 12:18 AM
  #23
bain_bk's Avatar
bain_bk
http://www.mustangtuning.com/sct-xcalibrator-2.html
these are the things that i can change. I have heard to jsut leave the air fuel ratio alone. What should i do for every thing else?
Old Jun 29, 2006 | 12:32 AM
  #24
03YellowPony
ORIGINAL: bain_bk
Is that all? DAYUM. Now I KNOW the Diablo is MUCH better.
My recommendations
Advance spark 2 degrees
Shift mph 1st to 5mph
2nd 7mph
3rd 8 mph
4th 8 mph.
Don't max out any adjustments. That's just asking for trouble.
Old Jun 29, 2006 | 12:50 AM
  #25
flash20's Avatar
flash20
+1
Old Jun 29, 2006 | 07:36 PM
  #26
bain_bk's Avatar
bain_bk
thanks yellowpony i moved the spark up 2 degrees in all 3 catogorys, i moved idle from 690 to 740, i moved max rpm to 6000, made 1-2 shift 3 mph, 2-3 4mph, 3-4 4mph. it shifted at about 5850 rpms. Im afrade to move it up any more unless others have been sucesful with it. The only thing i didnt know what to put in was the shift pressure. It was from 0 to 25 % and i jsut left it alone, i did the same with the fan temps, i didnt know what to set them on, it said small fan then large fan. Let me know what you think i should adjust and what to set these lat 2 at. I left the air/fuel ration alone like you said, the last thing i need is problems.
Old Jun 29, 2006 | 07:42 PM
  #27
03YellowPony
ORIGINAL: bain_bk
What's the shift pressure at now?
And leave the fans alone.
Old Jun 29, 2006 | 07:49 PM
  #28
bain_bk's Avatar
bain_bk
i left the pressure at 0. I called the guy i bought it from today and they said i have to fine tune all that stuff and to jsut try different things. Does every thing else look good to you shoudl i put more or less of something. I have about the same mods as you did except for gears and tlok. and i set every thing to about half of the max, cause i didnt want to max any thing out cause like u said they def brings trouble
Old Jun 29, 2006 | 09:19 PM
  #29
03YellowPony
ORIGINAL: bain_bk
Set it to 15%. No more. It will almost be like adding a shift kit.
Old Jun 29, 2006 | 10:09 PM
  #30
bain_bk's Avatar
bain_bk
ok i will try it out tonight. Thanks again You have helped me with every thing very fast.
Luke9222
Oct 22, 2015 11:55 PM
kmad61
Tuner Central
Sep 18, 2015 05:02 PM
04stangman
Sep 17, 2015 01:45 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
Sep 1, 2015 08:16 PM
