Winter Project
Well, when i put my stang away for the winter i want to get in to the engine!! I need some opinions should i just build an engine or use my stock block?? If i use the stock block what mods should i do inside the engine? or any other mods on the car? Thanks
well im doing basically the same thing.
supersixmotorsports.com
im getting the power pack, with that you will have a strong engine and can then supercharge and run NOS and nothing should blowup. a stronger clutch, 8.8inch rearend with 4:10gears and a t-lok, aluminum driveshaft. then your car will be strong plus you would have a fast *** sixer!
ORIGINAL: 561boii
ORIGINAL: pyromania
what about forged internals. the powerpak is just heads, upper and lower intakes, and a cam. you will need forged pistons and rods to run big boost safely. i would get the 4.3 stroker if i were you. and as for some people saying it is for boost only, they run it on their NA coupe
ORIGINAL: 561boii
Matt's 95 Stang
Oct 5, 2015 07:16 AM
