CAM's
Old 07-22-2006, 03:12 AM
006Banger
006Banger's Avatar
Default CAM's
Just want to get some opinions on which cam i should go with an what are the benifits of a installing a Cam Plus what can i expect from a new cam! Thanks Every1
006Banger is offline
Old 07-22-2006, 06:31 PM
Verado
Verado's Avatar
Default RE: CAM's
I was wonderig the same thing.
Verado is offline
Old 07-22-2006, 11:04 PM
cobra232
cobra232's Avatar
Default RE: CAM's
with a cam on a procharged 99+ you can expect 40+rwhp with the right cam. add heads and intake 90+rwhp
contact mik at www.rpm-mustangs.com he can supply you with what you need
also RGR over at www.v6power.net is a cam guru. give him a PM
the Comp cams biggest cam seems like it would be a dam good cam for a procharger
here are the specs
part# 44-704-9 Grind # 273HR112
218/224 dur intake/exhaust
.500"/500" lift @ 1.6 ratio rocker. .540"/.540" lift with 1.73 rocker. .5625"/.5625" lift with 1.8 rockers
112 deg lobe sep angle
you will need .600" lift springs. stock springs won't work
this cam on a stock headed 11 psi 99+ 3.8 should make 330-350rwhp
cobra232 is offline
Old 07-23-2006, 03:14 AM
jthorn9
The Godfather
jthorn9's Avatar
Default RE: CAM's
Damn that's a pretty agressive cam.
jthorn9 is offline
Old 07-23-2006, 04:36 PM
Rook6
Rook6's Avatar
Default RE: CAM's
Okay I'll be the one to ask.....anyone wanna break all that down Barney-style for the rest of us?
Rook6 is offline
Old 07-23-2006, 10:44 PM
jthorn9
The Godfather
jthorn9's Avatar
Default RE: CAM's
218/224 intake/exhaust - that's the duration of how long each lift last, don't know what that converts over to in real time. 218 is the intake duration, 224 is the exhasut duration, the cam opens the valves to let air in, this last a period of 218, then the cam opens the valves after detonation to let the air out the exhaust, that's 224.
.500"/500" lift @ 1.6 ratio rocker - this is how high the cam raises the valves to let air in, the higher and longer the duration, the more hp generated. it raises the valves equaly for intake and exit at 0.5"
jthorn9 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: CAM's
