Fog Lights
Old 07-02-2007, 10:54 PM
cglen07
cglen07's Avatar
Default Fog Lights
So i have a 2000 V6 coupe. A few months ago i installed a set of fog lights on it and they worked perfect for the first couple of months. a couple days ago they just stopped working all together. when they first stopped working the green indicator light which has the fog light emblem on it also went out, but the orange on off bulb still came on. after jiggling around the wires in the harness and the remote switch wire connecting to the switch, the on/off indicator light also went out. hopefully one of you knows something about this aftermarket fog light system and can help me out with trouble shooting tips. thanks in advance. here is a link to the fog light set i bought, hopefully that will help http://www.blueovalindustries.com/pr...p?pid=99011428.
-chris
cglen07 is offline
Old 07-03-2007, 04:33 AM
eddiev22
eddiev22's Avatar
Default RE: Fog Lights
#1 get clear ones
#2 check the ground wires
eddiev22 is offline
Old 07-04-2007, 01:16 AM
cglen07
cglen07's Avatar
both of the ground wires are still connected well. i got the on/off indicator light to start coming on again, but the fog light icon still wont glow. and the fog lights wont go on. im guessing the problem is in the remote box but im not sure. any way... i though about getting clear ones but i wanted more of a factory look then aftermarket.
cglen07 is offline
Old 07-04-2007, 01:17 AM
cglen07
cglen07's Avatar
actualy i think its called the relay box or something, im not sure though
cglen07 is offline
Old 07-04-2007, 01:47 AM
crmstang
crmstang's Avatar
how do you install gt fog lights on a 2000 model? do you cut out the slots or how do you go about doing that?
crmstang is offline
Old 07-04-2007, 01:58 AM
Archion
Archion's Avatar
The gt front bumper and the v6 are the same, just cut the grills out, the mounts are already there.
Archion is offline
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
lincolnshibuya
12-08-2015 04:37 PM
Explosive
10-02-2015 07:45 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Fog Lights
