This might be a problem...
Old 07-19-2007, 09:53 PM
ScottXL
ScottXL's Avatar
Default This might be a problem...
[1998 V6 Coupe]
My car's exhaust smells really bad. I'm not talking about when you bend over and take a whiff. I drove to a friend's house today to give him some money, and I opened my door, and the smell just overwhelmed me. Also, it randomly starts to kinda of sputter. It'll kind of jerk forward a few times, not a big jerk, just a little. I don't loose power, or RPM. I have no clue what it is. I have the Fuel Injector cleaner in my tank, and I'm about 3/8th of my tank left, and it's still doing it.
Could it be I have a bad injector? I also have a 'Check Engine' light on. The person I bought it from said it's been on forever, she went to the shop and they said it was an electronic error that doesn't really need to be fixed. I'm gunna get it fixed whenever I can. But, maybe the light's for the injector?
ScottXL is offline
Old 07-19-2007, 10:06 PM
WhitePony02
WhitePony02's Avatar
Default RE: This might be a problem...
I'm no expert on singleports, but I know that the head gaskets blow fairly easily.
http://wiki.answers.com/Q/What_are_t...wn_head_gasket
The first answer says "white colored or sweet smelling exhaust."
I did a "find" for smell on the page, and a few results came up. If its sweet smelling, you're not going to be happy.
WhitePony02 is offline
Old 07-19-2007, 10:41 PM
ScottXL
ScottXL's Avatar
What the hell is "sweet smelling"?
ScottXL is offline
Old 07-19-2007, 10:46 PM
WhitePony02
No clue, lol I'm not even sure if your nose can distinguish between sweet, sour, bitter..oh well, just look at that page and look in your engine for some of those signs.
Old 07-19-2007, 10:49 PM
HornyHornyHippo
HornyHornyHippo's Avatar
Does it smell like rank BO or a portapotty, or does it smell like cotten candy. Bitter - sweet
HornyHornyHippo is offline
Old 07-19-2007, 10:53 PM
ScottXL
ScottXL's Avatar
Nah. None of those. You can't see anything coming out of the exhaust. Nor do I feel any real performance loss... or coolant over-flow. Infact, my engine runs pretty cool.
And I can't really describe the smell. It just smells.... bad.
ScottXL is offline
Old 07-20-2007, 12:29 AM
MantaDreams
MantaDreams's Avatar
ORIGINAL: ScottXL
A blown head gasket dumping coolant into the chamber, boiling in the combustion process, and exiting the exhaust has a "sweet smell." Hard to explain unless you smell it for yourself... its just the best way to describe it. And the best way to know for sure is using the two other symptoms: white puffing smoke (steam), and unexplained loss in coolant, although sometimes the coolant leak can be so slight that it doesn't have enough vapor to condense into the white smoke.
It is a completely different smell than uncombusted gasoline, or burning oil.
I don't know what the OP means by a really awful smell, a really bad smell. I never thought of any smell as being really bad, or really good, although burnt oil tends to make me nauseas.
To help the OP, need a few more clues. Color of smoke, if any, operating conditions causing the smell.
Or buy a code reader and read the code. "Just an electronic error" please, that mechanic was not doing you any favors.
There are a number of codes for injector faults, but an injector is just a on/off valve for fuel to be sprayed right in front of the intake valve.Might be the answer if you consider gasoline smell as "reaally bad."
When you say you have a bad smell as soon as you exit the vehicle, sounds like you have some dead animal (or other foreign material) baking on your exhaust.
A cat cooking on your cat. Not a pretty picture.
MantaDreams is offline
Old 07-20-2007, 12:46 AM
Cmpfreak88
Cmpfreak88's Avatar
[sm=funnypostabove.gif]
I actually had a friend who called me once telling me her car was making meowing noises... I told her to pop the hood and try and look to see if maybe a belt was slipping or something when I hear her open the hood and she screams, "Oh my God, Tigger!" (Her cat's name)
Cmpfreak88 is offline
ScottXL
ScottXL's Avatar
ORIGINAL: MantaDreams
ORIGINAL: ScottXL
Haha, thanks. I found this post humorous and helpful.
I haven't gotten any codes for it yet. I just wanted to see if anyone could figure it out.
As for the smoke: there is none. A while ago it let out one really really light gray puff of smoke... and that's it. I don't think I'm losing any coolant, and it does kind of smell like burning oil.
ScottXL is offline
Old 07-20-2007, 01:03 AM
ScottXL
ScottXL's Avatar
ORIGINAL: Cmpfreak88
I LOL'D! [sm=smiley20.gif]
ScottXL is offline
fablefifty
12-29-2006 10:32 PM
x9Mustang9x
12-14-2006 02:20 PM
Airman21
11-17-2006 04:10 AM
XXC
09-19-2006 05:12 AM
mstng675l
05-25-2005 03:02 AM
Quick Reply: This might be a problem...
