parking brake cable breaking
Old Feb 6, 2005 | 10:46 PM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: parking brake cable breaking
I don't get why it snaps either. I've never seen a parking brake cable snap before. If your able to pull the parking brake lever all the way up and it still isn't applied it sounds like there is too much slack and I don't see why the cable would snap. I'm not sure where your located, but if your around columbia, md I can adjust free of charge. It only takes about 10 minutes. Or you could be take it to midas or minakee and have them look at it. They shouldn't charge to much to adjust the parking brake.
Old Feb 6, 2005 | 11:02 PM
Hutch22's Avatar
Hutch22
i'm in alberta, canada so quite a way from you. but thanks for the offer.
Old Feb 7, 2005 | 12:30 AM
DaGGer's Avatar
DaGGer
you know what....if you can look at it look for anything that may be hitting it or rubbing on it to see if its that...have it pulled up and everything and check the whole thing
Old Feb 7, 2005 | 09:13 PM
Hutch22's Avatar
Hutch22
sounds good. its too cold outside to replace it now. But it must be rubbing on something for it to snap like that. none the less it sure is a pain in the a$$
jc409
Convertible Tech
Sep 24, 2015 03:38 PM
jstrothe
Sep 24, 2015 12:17 PM
ccdguy
Sep 19, 2015 05:20 PM
LivingInThePast
Sep 16, 2015 12:20 PM
DoctorScary
Sep 9, 2015 07:53 AM
