Squeaking Like Hell
Old Sep 14, 2008 | 08:36 PM
winner99's Avatar
winner99
Default Squeaking Like Hell
My whole suspension is starting to squeak like hell. Its been chirping over bumps but now its getting pretty bad. What other bushings could be bad except the spring isolators? The local mechanic said he'll put my new springs, shocks, and struts on for $150 so I dont wanna put it on if theres something that could be fixed at the same time.
Old Sep 14, 2008 | 09:49 PM
Cryptostorm's Avatar
Cryptostorm
your going to drop about 550 just in parts.... but the $150 is a pretty good deal as far as labor goes
Old Sep 14, 2008 | 10:32 PM
winner99's Avatar
winner99
Im not buying a new suspension because it squeaks. I have always planned to but while its up there I mightas well ask.
Old Sep 14, 2008 | 10:36 PM
Cryptostorm
new springs and struts all around are going to cost that much... you could maybe cut that back to 400 if you go with the cheap stuff..
Old Sep 14, 2008 | 10:38 PM
TurtleSLow's Avatar
TurtleSLow
uh it could be the ball joint? mine started squeeking and i replaced it and its fine
Old Sep 14, 2008 | 10:41 PM
Cryptostorm
its probably just a bushing
Old Sep 15, 2008 | 12:37 AM
sransari's Avatar
sransari
you should change shox/struts every 60-65k miles anyway for safety. when i had squeeking over bumps, it was the shox.
Old Sep 15, 2008 | 06:32 AM
defconfire's Avatar
defconfire
I would check the rear lower control-arm bushings. Or perhaps the A-arm bushings up front.
Old Sep 15, 2008 | 09:08 AM
moontang's Avatar
moontang
perhaps tie rod ends just to throw a possibility out there mine squeeks and i know thats what it is for me
Old Sep 15, 2008 | 09:45 PM
patswanson2001's Avatar
patswanson2001
I had the same squeek on my 98 stang. I too thought it was the suspension. So I bought the Bullit suspension kit and decided not to replace the lower control arms but was so sure it was a bushing in the lower control arm . Unfortunately I was out of cash. The tech said it was a brake hose holder stop or something to that effect. Nothing to do with the suspension and the part wasn't really nesssary so he took it out...
The good news.. I don't have a squeek and I have a way better handling stang... the bad news... I spent 600 bucks to get rid of the noise when I could have used white spray grease and done it myself for FREE....
cheers
P@
98 triple black V6 vert
2007CalSpec
Dec 13, 2020 11:42 AM
drfister
May 3, 2018 10:38 PM
Sminemann
Sep 17, 2015 09:24 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
