help quick!
Old Sep 27, 2008 | 09:31 AM
mymustang44's Avatar
mymustang44
Originally Posted by 03sixbanger
No need to yell. We are just trying to help you. Mymustang44 also has the windstar so he has more experience with it than i do. But when i run out of ideas like this, if it were me, I would just take the intake off and do it again but slower....It doesnt take that long anyways
Yea it doesn't take long to install plus its not that in depth of an install. There are not alot of things that can go wrong with this. Can you take a couple of pics of your vacuum lines and your whiole setup. that would help alot.
Old Sep 27, 2008 | 10:06 AM
ramoyer1's Avatar
ramoyer1
ok i think we got the rpm thing fixed but now the throttle is not turning it is just pulling it back when we push the gas pedal.how do i fix this? we have to open it by hand
Old Sep 27, 2008 | 10:10 AM
TurtleSLow's Avatar
TurtleSLow
i dont have any experience with this install but i heard you have to do something with the throttle cable where it meets the pedal
Old Sep 27, 2008 | 10:11 AM
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
did the throttle cable come loose from the pedal?
Old Sep 27, 2008 | 10:53 AM
richmustang1880's Avatar
richmustang1880
i had the same problem with the throttle arm no matter how much i space it it wouldnt open that far and it would start to bend. my solution was to run the throttle cable ontop of the upper bolt the tb almost opens all the way but i really cant notice any hint of a problem. my rpms did go really high at first check your wiring i had a loose wire problem solved. my rpms lag now(when i stop at about 1300-1100 for a minute) but its the same problem some 4.6 guys have im going to make a new gasket for my iac with a smaller hole most likley solve that problem.
Old Sep 27, 2008 | 11:06 AM
03sixbanger
Ryan's Backup Mod
take some pics of your throttle cable on both ends...let us look at it
Old Sep 27, 2008 | 02:21 PM
ramoyer1's Avatar
ramoyer1
ok will post asap
Old Sep 27, 2008 | 03:25 PM
ramoyer1's Avatar
ramoyer1
ok we got code on my tps.....I think we took care of that now it just has a off bad idle. heer maybe you guys can hear it.
http://www.axcessmypics.com/ramoyer1...b3/jsps/entry#
Old Sep 27, 2008 | 03:27 PM
03sixbanger
Ryan's Backup Mod
i cant watch it on this computer...upload it through photobucket.......what do you mean by bad off? becuase you can do a little adjusting
Old Sep 27, 2008 | 03:35 PM
ramoyer1's Avatar
ramoyer1
it is a video.....but i will try
