help quick!
Old Sep 27, 2008 | 03:39 PM
  #21
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
photobucket does videos too
Old Sep 27, 2008 | 03:40 PM
  #22
ramoyer1's Avatar
ramoyer1
http://s248.photobucket.com/albums/g...0927081615.flv
Old Sep 27, 2008 | 04:40 PM
  #23
03sixbanger
Ryan's Backup Mod
hmm....i cant really hear anything...spray some soapy water around and see if it revs up
Old Sep 27, 2008 | 05:02 PM
  #24
ramoyer1's Avatar
ramoyer1
yea ok it sounds like a have a VERY VERY BIG cam it in.
Old Sep 27, 2008 | 05:14 PM
  #25
mymustang44's Avatar
mymustang44
Sounds like you're having the same problem as 03to07 did when he had one. He had to reinforce hid arm. Or if you have a taller hood you can run it the right way, over the top of the intake. Seriously though. Take some good up close pics.
Old Sep 28, 2008 | 03:45 PM
  #26
ramoyer1's Avatar
ramoyer1
Ok the arm will have to go on th back bunner! The tps keeps throwing a code. we have checked the lines 4 times and they are right and tight. Is there a way to put it on the throttle body? and the starts up and run fine no vac leaks but when i go to give it gas it dies almost. could this be the tps not working?
Old Sep 28, 2008 | 04:02 PM
  #27
cuban tech's Avatar
cuban tech
it could be in the video i didn't see your intake tube with the maf that could also cause the bad idle
Old Sep 28, 2008 | 04:15 PM
  #28
ramoyer1's Avatar
ramoyer1
well that could be a part of it but like i said when i go to give it gas it dies pretty much
Old Sep 28, 2008 | 04:26 PM
  #29
03sixbanger
Ryan's Backup Mod
well when you hit the throttle, the tb opens and sucks more air...so if the maf is messed up then it can cause problems
Old Sep 28, 2008 | 04:27 PM
  #30
ramoyer1's Avatar
ramoyer1
cause it to die? wht does the tps do cause it is still putting out a code. i will get a vid really quick
