help quick!
Old Sep 28, 2008 | 04:41 PM
  #31
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
well it could be bad too. anything is possible. lets see the vid
Old Sep 28, 2008 | 04:47 PM
  #32
mymustang44's Avatar
mymustang44
Wait. You do have the maf on you intake right?? Ant the tps tells the computer how far the throttle body is open so it can adjust fuel accordingly. Make sure all your wires are right cause i know you had to cut them to extend them.
Old Sep 28, 2008 | 04:51 PM
  #33
ramoyer1's Avatar
ramoyer1
Crappy vids but they might get the job done
http://s248.photobucket.com/albums/g...928081729a.flv
http://s248.photobucket.com/albums/g...0928081729.flv
Old Sep 28, 2008 | 04:54 PM
  #34
03sixbanger
Ryan's Backup Mod
yeah the previous posts kinda made it sound like you didnt even have the maf hooked up lol
Old Sep 28, 2008 | 04:55 PM
  #35
03sixbanger
Ryan's Backup Mod
uh yeah. you have nothing past the throttle body.
  #36
mymustang44
Stick your intake back on and hook the maf back up, then try it. Your car will not run good without it.
Old Sep 28, 2008 | 05:03 PM
  #37
ramoyer1's Avatar
ramoyer1
so what is up with the tps will it throw the code for the same reason?
Old Sep 28, 2008 | 05:24 PM
  #38
ramoyer1's Avatar
ramoyer1
new vid tell em wat you think! the only reason i have not out my other pipe on is egr delete so
http://s248.photobucket.com/albums/g...0928081814.flv
Old Sep 28, 2008 | 07:09 PM
  #39
cuban tech's Avatar
cuban tech
ok when you tried it with the stock maf just to try you said your self it was respondeing better due to the maf conneted this time i would run the intake tubbing with the maf. clear the codes disconect the negative battery cable and then wait 2 min the reconnect and then try again. and see if that helps if the tps is still bad and throwing a code i would see if you can get another one and try that out.
Old Sep 28, 2008 | 07:10 PM
  #40
03sixbanger
Ryan's Backup Mod
i may have a tps laying around
