afr gauge
Old Aug 18, 2009 | 12:50 PM
tranceaddict's Avatar
tranceaddict
Default afr gauge
well, im going to get an sct tuner as soon as i sell my old subs =] so i want to pick up a good afr gauge to make sure the tuner doesnt lean my car out too much or anything and also for future use as i plan on putting spray on in the future.
Now ive looked on american muscle and found a gauge but i know that it needs a wideband not the normal narrow band 02 sensors but where can i pick up one complete with a wideband, or are the mustang 02s already widebands?
Old Aug 18, 2009 | 01:11 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
I have an autometer wideband, it comes with a bung that you get welded in before your cats at the collector on the manifold/header, It was REALLY easy to install too. I don't have mine connected to my tuner, and don't ever plan to.
Old Aug 18, 2009 | 03:49 PM
tranceaddict
i wasnt planning on hooking it to my tuner either, just making sure the a/f ratios are in check but the stock narrow band will work?. i know that aem makes gauges that come with a wide band o2 sensor but im not sure if that style sensor will work with the mustang. I'll check out the auto meter one. any more suggestions
Old Aug 18, 2009 | 04:02 PM
RyansQuick6
Reverse Gear Member
The autometer will work perfectly and it comes with the everything you need.
This is the one I have
http://www.thunderracing.com/catalog...d=786&pcid=190
Old Aug 18, 2009 | 07:43 PM
tranceaddict
damn thats kinda high, would this one work?
http://aempower.com/ViewProduct.aspx?ProductID=73
Old Aug 18, 2009 | 09:17 PM
RyansQuick6
Reverse Gear Member
Yeah that one will work. I went with Autometer over the AEM due to the fact that my cluster is Autometer and I wanted my gauges to match
Old Aug 18, 2009 | 10:07 PM
cuban tech's Avatar
cuban tech
don't forget you need 2 if your running true dual exhaust as you need to check A/F at both bank's
Old Aug 19, 2009 | 11:18 PM
Mustang3GT07's Avatar
Mustang3GT07
I'm running the AEM Wideband and It works great!
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
