maf or cable?
Old Dec 28, 2009 | 12:33 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Originally Posted by bstd3.8
so how can i up the pressure? I just got a code reader and i am running lean. I am replacing the fuel filter in a couple of days but what if that does not take care of it?
You shouldn't need to up fuel pressure, thats not going to solve your problem. You need to fix whatever is wrong with your pile.
Old Dec 28, 2009 | 01:54 PM
bstd3.8's Avatar
bstd3.8
ok so it's running lean. Doing filter Friday.... what else could cause it to run lean? could the injectors be dirty?
Old Dec 28, 2009 | 03:48 PM
neo8222's Avatar
neo8222
there are a lot of things that could make it run lean. MAF, O2, and pretty much any other sensor on the induction side of it. also is it a single bank running lean or entire engine.
Old Dec 28, 2009 | 08:32 PM
bstd3.8's Avatar
bstd3.8
the reader is just stating that it is running lean no other codes are given
Old Dec 28, 2009 | 09:52 PM
neo8222's Avatar
neo8222
does it give you a actual code number? it will be like P1131 for example if not taking it to auto zone to get it read and have them get you the actual code. this will help narrow down the problem.
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
Explosive
Oct 2, 2015 07:45 AM
