Inside light wont shut off.
Old Feb 6, 2010 | 03:48 AM
robinson209's Avatar
robinson209
Default Inside light wont shut off.
My stang is a vert, so the inside light is in the rear-view mirror. It has always functioned normally.
However, the last couple days it will stay on after I close the doors and even after I start the car. I drove all the way home tonight and it never shut off. It has been doing this the last couple days.
Even when I park and lock the car, the light stays on and doesn't dim away like it normally does after I press the lock button on the key fob.
I have done the usual stuff like checking the fuses, messing with the switches, closing and locking the doors multiples times, but nothing seems to work.
Any ideas?
Old Feb 6, 2010 | 04:02 AM
NeoTokyo's Avatar
NeoTokyo
Unplug it so it doesnt drain your bat or trade with me for my Coupe's rear view.
By any chance did you happen to get water on it by accident? Water could be jumping the circuit causing it to stay on. The plug could also have water in it as well.
Try taking it off and putting it ontop of your fridge or over a heater vent for the night to see if that helps. You can also use a hair dryer set on low.
I like the vert's rear view mirror quite a bit because it has more heft to it and doesnt jiggle around like every other coupe mirror I have ever seen.
Whenever I find one cheap I buy it.
Old Feb 6, 2010 | 01:25 PM
neo8222's Avatar
neo8222
make sure you didnt turn the dimmer switch all the way to the left after it clicks the lights turn on.
Old Feb 6, 2010 | 01:28 PM
Synyster06Gates's Avatar
Synyster06Gates
Does it think the door is open? My Ranger had the same problem. Spray some WD40 in the door latch and see if it goes away. Be very very liberal with it. And do both doors
Old Feb 6, 2010 | 06:52 PM
Fink's Avatar
Fink
My dome light stayed on all the time... I didnt know the fix so I just took the bulb out. Then one day I found the fix and the WD40 in the door latches really works.
Old Feb 7, 2010 | 10:02 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
The switch is built into the door latch, spray the latch really good with some wd-40 and it may come unstuck.
Old Feb 8, 2010 | 04:17 PM
robinson209
Sprayed WD-40. Worked!
As always, THANK YOU ALL FOR THE HELP!!!
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
TfcCDR
Sep 14, 2015 12:08 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
amandahchase
Sep 3, 2015 10:09 AM
