LSD?
Old May 17, 2011 | 02:33 AM
rumo1112's Avatar
rumo1112
Question LSD?
I found a 2001 V6 3.8 Mustang at the junkyard and it appears to have LSD, but i have a 1996 V6 3.8 Mustang, is the whole rear axle pumpkin interchangeable with my rear axle pumpkin?
Old May 17, 2011 | 04:41 PM
mustangman02232's Avatar
mustangman02232
its an 1" wider IIRC, did you pop the cover? are you sure it has LSD because stock no v6 has an lsd
Old May 17, 2011 | 08:40 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
It's a half inch wider on each end and will bolt right up, but you'll need the newer lower control arms. If it's a 7.5 then it's probably not lsd
Old May 17, 2011 | 09:49 PM
stangant's Avatar
stangant
you will need to look at the gt's for that, but i say stick with the 99 + for the older car. makes it look like it has wheel spacers and looks good.
nonstopred
Jul 31, 2006 12:34 PM
V6MustangKnight
Jun 20, 2006 10:03 PM
HxCory
Jun 2, 2006 06:15 PM
TJ
May 16, 2006 08:52 PM
Big Red
Mar 6, 2006 10:25 PM
