Wheel spacers?
Old Mar 29, 2018 | 04:52 PM
AncientVampyre's Avatar
AncientVampyre
Default Wheel spacers?
Hello everyone, I am new to the forums I need help with a question I have about wheel spacers and will I need them on my 04 mustang? Right now I am running on stock rims which are 215/60/16 all around and I am going to put 265/35/18 for the front and 285/35/18 for the rear so will I need spacers or will they fit without?
Old Mar 29, 2018 | 06:12 PM
08'MustangDude's Avatar
08'MustangDude
Banned
The 265/35/18 will be .9" Shorter, and 2" Wider. You don't want wide tires up front. You don't
want to go too far down in height either.
The 285/35/18 will be .3" shorter, and 2.6" Wider. 295/35/18 will retain the 16" wheel's height.
You won't need spacers, you have to remember, that, even if you go 2" wider,
that's 1" wider on each side of the tire, from center of the tread to each edge.
The whole 2" doesn't go to one side.
https://tiresize.com/calculator/
Old Mar 29, 2018 | 06:29 PM
AncientVampyre
thank you the reason I was wondering that is because I am installing 12.88" wilwood brake discs along with 99-04 SVE series 2 wheel&tire kit 18x9/10 machine lip with Sumitomo ZII tires from Late Model Restoration
Old Mar 29, 2018 | 06:40 PM
08'MustangDude
Banned
Well, then that may be a different story, with stock back-spacing and bigger calipers.
If you go more positive offset, you probably won't need spacers. See what the
offset is on the rims you're getting.
Old Mar 29, 2018 | 06:44 PM
AncientVampyre
Wheel Specs
Offset: +20mm
Backspacing: 6.29
Lip Size: 2.84"
Weight: 24.86lbs
Lug Pattern: 5x114.3
Offset: +24mm
Backspacing: 5.95
Lip Size: 1.34"
Weight: 24.20lbs
Old Mar 29, 2018 | 07:15 PM
08'MustangDude
Banned
Stock '99-'04 rims are at least ET24 (+24) Offset, +26, and GT +30. Did not find the
back-spacing.
The front end of a Mustang is set up in a way that will fit at largest a 9” rim with stock
components. The bigger brakes will be up front, so that's probably a definite yes for
spacers, unless the back spacing is more than the stock.
Rear? Stock? With the independent rear suspension (IRS), using a larger wheel means the
tire’s sidewall will rub the rear IRS subframe-mounting bolt. However, by changing out the stock
half-inch factory IRS subframe bolt with a shorter one, you can use 17x10.5” rims. A 10.5" rim can
handle up to 315mm wide tires. Solid Axle, rims need to clear the calipers...
Big brake kits don't always fit under the stock rims. Pushing the rims out an inch or so will give
the calipers more room to breathe, and you don't have to worry about scarring the inside of your
rims or the brand new calipers.
There are some things to keep in mind before slapping on a set of spacers and calling it a day.
Too big of a spacer can actually hurt your Mustang more than the wider stance could help performance.
Oversized spacers can negatively affect the scrub radius (imagine two lines: one through the center of
the tires and another following the angle of the suspension. The difference between where those two
lines meet and the road surface is the scrub radius). Ideally, your scrub radius will be zero for optimal
performance. Too large of spacers can move the scrub radius and overstrain suspension components
(wheel bearings, ball joints, and tie rods), making them wear out faster. All things considered, make
sure you don't over shoot what you need.
Old Apr 4, 2018 | 08:57 AM
NYstang's Avatar
NYstang
MF Staff Snitch
back-spacing.
No IRS on these cars, only SN95's that had it were the 99-04 cobra, or if it was swapped. Considerng he is asking this about wheels, I would assume no IRS swap (no offense OP).
These wheels will fit, no spacers needed.
Go with taller/wider tire on the rear. On a 10" wheel, 285 is pretty narrow. 295/25 or 305/35.
Old Apr 4, 2018 | 09:12 AM
AncientVampyre
They worked with no spacers and I would of went bigger but they were the only ones they had at the time They worked with no spacers
2k1gt
Jan 29, 2005 12:34 PM
GT1999
Jan 11, 2005 01:39 PM
tarpymac
May 15, 2004 03:08 PM
whitelightning
Dec 1, 2003 07:24 PM
tbeckman
Nov 30, 2003 11:27 PM
