Sixxer chat
tempting but nah i like fr500s
guy said he will give me my money back, if its just the axle then its the same axle from the 7.5 right? but if i find a straight edge to check out the tube and its bent then its going back
As long as its the same year range (99-04) and a GT rear end that means they are the same length and 28 spline.
yeah but what if the axle tube is bent? i mean idk how hard the rear was hit but i dont know if the tube would bend if the axle was bent a 16th of an inch. i dont want to run into problems later
Mark perfect center on each side of the tube.
Use a laser pointer to connect the two and check down the beam for perfect center.
Do this in an X fasion so you cover at least four angles.
You can even strike a chalk string line and check that way too.
