Just how much abuse can a Ford V6 take?
Old 02-01-2010, 10:08 PM
Clif Brohn
Clif Brohn's Avatar
Originally Posted by hpwrestler220
Spinning up to 6000 is pointless at stock-ish power levels. Unless you have hopped on a dyno and have seen that you are still making power that high in your RPM's.
I'm still building momentum up to 6,000rpms; which is more what autox is about than anything else.
The reason i run the car so high has been that even with 3.73s, the bottom of second bogs bad enough i just run faster pushing that high of rpms vs. shifting into second gear for two seconds, then back into first. I'm looking to remedy this though. NT05s are waiting for autocross season to start, so hopefully they'll provide enough grip to make second gear worth something!
automatic trans BTW
with ported upper/lower intakes the motor should make power higher than 5300-5400rpm. Probably not to 6,000; but 5700rpms shouldnt be out of the question
Clif Brohn is offline
Old 02-02-2010, 12:43 AM
TurtleSLow
TurtleSLow's Avatar
well if you have that much power second gear will probably not bog like that, it would be better to grab that low end torque than ride out high rpms
TurtleSLow is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
Granatelli Sales
01-20-2020 12:34 AM
JonnyBlazeGT
11-03-2015 01:10 AM
mustangchef
09-04-2015 08:08 PM
AMAlexLazarus
AmericanMuscle.com
09-02-2015 08:59 AM
Quick Reply: Just how much abuse can a Ford V6 take?
