Lurker coming forward..06 Pony..
Old 01-12-2007, 01:41 PM
8cd03gro
8cd03gro's Avatar
Default RE: Lurker coming forward..06 Pony..
they can only void your warranty if they can prove that the mods you did broke the part that is broken. so let's say you do even full exhaust....your warranty on your tranny, your motor (if the exhaust is done right) your exterior, interior, axles, rear end, etc etc.....everything should be fine, but obviously they aren't going to warranty the part that you put on.
8cd03gro is offline
Old 01-12-2007, 06:44 PM
LX200
LX200's Avatar
ORIGINAL: wolfey2k
ORIGINAL: LX200
Changing the exhaust sytem does NOT allow more air to flow into the car due to less backpressure. As a piston moves down and fills with air, the inlet system is not in any way in contact with the pressure in the outlet system. A dual muffler, or more free flowing single helps the car because the engine wastes less pressure pushing the exhaust gas out the cats and pipes and muffler.
Okay, I can seewhat you're saying but you areincorrect.Although I can get into a rather long explanation, cam shafts areset up for what'sknown as valve overlap. The period of valve overlap is constant throughout the entire RPM band on the 4.0.
Valve overlap is when both intake and exhaust valves are open at the same time. Not a lot but they are both open.Trust me, opening up the exhaust 'does'effect the intake volume and velocity just like it effects overall VE. The engine breaths better, period. The varioussensors see this change. The MCU adjusts things accordingly.
If the exhaust valve is open at the same time as the inlet valve is open, then any extra flow you are getting is moving into the piston and right out the exhaust. Net result... no more air in the piston during detonation.
LX200 is offline
Old 01-12-2007, 06:54 PM
Ronaele05
Ronaele05's Avatar
incorrect, It is a fact that more valve overlap results in scavaging the intake air, basically the faster the air leave the more is pulled in. it happens so fast that the air that is pulled in doesn't have time to leave so it fills the cylinder better. Kinda like a ram-air scoop. Air is FORCED into the combustion chanber. Although opinions are allowed on the matter, i have heard that from all of my instructors and people i asked
Ronaele05 is offline
Old 01-12-2007, 11:02 PM
cstigger04
cstigger04's Avatar
Doesanyone one else since a catfight coming?
cstigger04 is offline
Tivo304
08-28-2023 12:19 PM
bjdutch2005
03-24-2017 03:38 AM
zsmart
Convertible Tech
02-29-2016 08:33 AM
uedlose
09-10-2015 03:30 PM
tmdm
09-04-2015 06:45 PM
Quick Reply: Lurker coming forward..06 Pony..
