Just wondering: N/A?
Just wondering, because I know you guys know a lot of inside information on things, is there any other n/a bolt-ons I'm missing from the listor ones coming out in the next few months I don't know about, Thanks ahead!:
-CAI/Tuner
-Duals/single hi-flow muffler
-headers
-udp
-Gears/t-lok
-Aluminum Driveshaft
-Screaming Demon coil and livewires
-throttle body
-P&P heads-by engine shop or purchasedonline and sent to you with your core sent back
-Cam-by engine shop or purchasedonline and sent to you and your core sent back
-Dyno tune
-CAI/Tuner
-headers
-udp
-Gears/t-lok
-throttle body
-Dyno tune
RE: Just wondering: N/A?
-throttle body
I heard this isn't worth the money.
This is some serious mods to your engine, no doubt this will void your warranty, is the gain worth the cost?
-throttle body
I would add drag radials to your list. What good is increasing engine performance if you cannot put all that power to the ground and make it stick? I ran 275/50-17 M&H Racemasters (28" dia) all last summer on the street (about 5K miles) and made about a dozen passes with them at the track, and I still have some tread left to start the 2008 race season. Other members really like the Micket Thompson ET Street DR's, but they have a smaller diameter (which may be a plus for certain people).
With DR's, you will need LCA's and maybe a new UCA too.
ORIGINAL: 28HopUp
-GT take-off bullits-w/drag radials
-rear upper and lower control arms
-BMR front sway delete/radiator support (weight savings)
-American muscle rear seat delete kit (weight savings)
-Remove trunk carpet/debris and spare tire w/jack (weight savings)
-Possibly lightweight k-member but $500 + install for minimal weight savings isn't the greatest thing compared to all the other options on the market
That's all I know for that, anyone knows any other weight reduction stuff in that area, post it.
ORIGINAL: ODDYSEY
-throttle body
-throttle body
Second part, my warranty is already done, but I doubt that ford would be able to tell(visually) if you installed the heads/cam. All you need is a good dyno tune. I don't know if it's possible for ford to check if you've done dyno tunes or reset your computer, but if they can you could always say I had another mechanic look at the car and check the computer before you brought it to them.
Aliate X
01-22-2005 05:34 PM
