Future Mods-Need Advice
Old Jun 11, 2008 | 02:14 PM
28HopUp's Avatar
28HopUp
MF Administrator
Default RE: Future Mods-Need Advice
ORIGINAL: AlloySixxer
If I get the C&L Intake and XCAL 3 first, will it need to be re-tuned when I get the 3.73 gears, suspension, T-lok? How do I go about doing this?
You can get your tunes now, and then change the settings in the handheld tuner for gears, larger diameter rear tires, etc.
ORIGINAL: acascianelli
Isn't the driveshaft in the V6 only good till like 115-120mph?
The driveshafts in the 2005 models had pressed-in u-joint caps. Those are the driveshafts that are prone to letting go athigh speed. At some point during the 2005/2006 model change over, Ford started putting in retaining clips. If you have a 2005 or 2006, you should look under the car to see if there are clips in place before plunkin' down $500+ for an aftermarket alum DS.
Old Jun 11, 2008 | 03:08 PM
AlloySixxer's Avatar
AlloySixxer
ORIGINAL: 28HopUp
Ok sweet, so I can fix my tunes when I get the gears. And I have a 2007 so no worries on the DS. Thanks!
CS2007
Jun 25, 2019 09:45 PM
Bokeo
Oct 10, 2015 08:28 PM
jim2015
Sep 14, 2015 08:09 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
