7.5 t-lock vs posi
7.5 t-lock vs posi
ok so i hav s197 v6 trying to make it into a drift car..
does it really matter which one i get t-lock vs posi?
and also do think its ok using used gears and lsd? lol trying to save some money.
and also i dont hav the money to get a 8.8 rear end.
I wouldn't use used gears/lsd if I were you just for the fact that the cost of install it what's going to be the expensive part. BUT...click the following:
http://www.mustangcollective.com/sho...&highlight=8.8
He has a 8.8 for sale for $300. I'd try that rout if you can. Good luck whatever way you go!
Sometimes an 8.8 takeoff is going to be much cheaper then getting a t lok and gears installed on a 7.5. I know when I upgrade I will be doing the 8.8 because I can one for around $800 shipped, and the install will be cheap around $100, where as gears and a t lok for the 7.5 plus install would cost me at least $1000 and could be more.
as for the intentions of the OP.... drifting? expect to spend a lot of cash on parts for the heavy wear and tear you'll be giving your car. also, u need a lot of torq which the 4.0 is no slouch in but not something you want to drift on stock power. if you are serious, then you really should get a much stronger posi. the FRPP T-Lok is fine for street use but i wouldnt bet on it for your intentions if you plan on drifting often. JMO.
