adding additional lights
Old May 15, 2010 | 01:53 PM
hornedfrog13's Avatar
hornedfrog13
I have red LED's in the front foot wells and in the rear on the side of my seats.
All i did to hook them up was run the wires straight to the battery and run a simple switch ($7 at autozone) and tack the switch to the underside of the foot well. It turned out really good and was simple to wire.
Old May 15, 2010 | 03:18 PM
157dB's Avatar
157dB
Cut & Paste Expert
Boy I sure hope you fused the wire at the battery.
Or you are going to have a carpet smoker if any
of the wires gets pinched...
I never liked hooking straight to the battery as
the battery terminals are not the best place to
pick up 12 volts.
They are already prone to corrosion as is.
Old May 17, 2010 | 10:34 AM
kc5mhb's Avatar
kc5mhb
Originally Posted by 157db
LEDs dont pull enough amps to warrant a relay.
Not enough to warrant a size bigger in the wire department.
Unless you are planning on adding hundreds but the
OP stated only 2 LED light bars?
84 watts of Fog lamps, YES to the relay, two LED lights, NO relay required.
Its just plain overkill.
Sorry charlie.
WIRING diagrams are available online.
The wire colors and locations are shown in detail for those that can understand....
Point taken, but then again I like to err on the side of too much protection instead of not enough. I can envision someone hooking up a bunch of little lights, neon lights, etc. and then wonder why the wiring burnt up. Its just the electronics technician in me showing through.
Old May 17, 2010 | 04:42 PM
ABQstang89's Avatar
ABQstang89
I added neons to the footwells last summer. I opted to use a switch and just ran an add a fuse to the fuse box in the passenger side footwell. Had a friend turn the keys to on position and I checked to see which fuses were hot. I know there is one that goes hot when the doors open, just gotta spend the time to look for it.
Old May 17, 2010 | 11:12 PM
hornedfrog13
same for me, takes a little bit but well worth it
Old May 19, 2010 | 11:30 AM
Moss Muscle's Avatar
Moss Muscle
Former Sponsor
Originally Posted by woodhall
whitehorse- thank! never even looked to see if they sold kits.
everybody else --
the link below is what he is talking about-35 bucks. ill see if i can find somebody on this forum tho with them instructions, i already have all the wiring and lights
it says tap into the "door switch"? anybody know what that is?
http://www.mossmuscle.com/Shop/ViewP...eIndexID=84719
Woodhall, I can email you the instructions for this kit if you want them. Of course, that's if you still need them. I would copy and paste on to this thread but it's a few page PDF file. It comes with pictures but im not sure what pictures would help you.
Let me know
mtgldr
Feb 3, 2024 09:00 PM
jhawkr
Oct 30, 2015 01:55 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
Colin Ringle
Sep 15, 2015 09:27 PM
amandahchase
Sep 3, 2015 10:09 AM
