MP3
Old Aug 3, 2005 | 07:10 PM
doc0075579's Avatar
doc0075579
Default MP3
Wondering if we can plug our MP3 Players to the Shaker 1000?? Says MP3 Compatible?
Old Aug 3, 2005 | 07:42 PM
CainMotorsports2102's Avatar
CainMotorsports2102
Default RE: MP3
i think that means it plays cd's that are in mp3 format
Old Aug 3, 2005 | 07:56 PM
rygenstormlocke's Avatar
rygenstormlocke
Default RE: MP3
Cain is correct, it will play CD's with MP3 files burned to them.
Old Aug 3, 2005 | 09:47 PM
ponytx's Avatar
ponytx
Default RE: MP3
Cain is right, you'll have to use an FM modulator if you want to use your MP3 player.
Old Aug 3, 2005 | 09:50 PM
hamidlmt's Avatar
hamidlmt
I ♥ Acer
Default RE: MP3
There's at least one company out there working on an adapter to utilize the AUX button on the Shakers
Old Aug 4, 2005 | 11:04 AM
ChristopherCamel's Avatar
ChristopherCamel
Default RE: MP3
yep "mp3" means it will allow data cd's to be played...tech terms all it means is that it is able to read the table of contents to know where each file/mp3 is on the cd
Old Aug 5, 2005 | 06:53 AM
S.SubZero's Avatar
S.SubZero
Default RE: MP3
Yeah I burned a CD (in regular data format, not audio CD). Got well over 100 tracks on the disc. Popped it in and it works fine. Shows the song name and artist on the display also. Does anyone know where it gets this? The filename or the ID tag?
Old Aug 5, 2005 | 01:27 PM
rygenstormlocke
Default RE: MP3
ID4 tag
Old Aug 6, 2005 | 11:07 AM
sam_abuelsamid's Avatar
sam_abuelsamid
Default RE: MP3
ORIGINAL: doc0075579
The auxiliary input on the new ford units (as used in mustang, f-series trucks, five hundred, etc) is intended for use with rear set entertainment systems. PIE has a new auxiliary input adapter for the new ford head units that makes the unit think that the entertainment system is plugged in. It is available for pre-order now from logjam electronics. http://www.logjamelectronics.com/piefrd04aux.html I just order one the other day. Once you plug this in you can plug in any mp3 player into the aux input and play it throught the stereo.
one_focused_svt
Jan 13, 2006 03:49 PM
princedonny
Dec 12, 2005 07:38 PM
princedonny
Dec 11, 2005 02:05 PM
RabidCharlie
Apr 27, 2005 08:00 PM
InfernoKron
Jan 26, 2005 10:09 AM
