hub cap problem
Old Jul 12, 2008 | 12:17 AM
stanging's Avatar
stanging
Default hub cap problem
Anyone know of someone that sells a replacement hub cap, (besides ford or a salvage) that is better made. This is for a 96' 3 spoke wheel with the "flat cap". The ones I get from the salvage are as brittle as the ones that I had to begin with.
I just hate to see my "new cap" pass me as I'm going around a corner(not hard or extra fast either)or coming to a stop.
Old Jul 12, 2008 | 07:20 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: hub cap problem
Ilike your 'cap passing you by' analogy
Do you have a picture of the wheel/cap in which you speak?, I am having trouble picturing it.
Jazzer
Old Jul 13, 2008 | 12:58 AM
stanging's Avatar
stanging
Here is a picture like my car.
Old Jul 13, 2008 | 06:56 AM
Jazzer The Cat
Retired Moderator
You must be driving those wheels pretty hard to continually lose those caps.
You could probably get some 2'~3' long stainless-steel screws and drill a small hole off center of cap.You then drill a small hole andtap into the wheel itself to hold cap in place. I used torun a set of wheels on my '85 GT that had bolts like this to hold the center cap in place. I doubt there would be a balance issue, but worth running by a tire shoppe for their input on my idea.
Good luck
Jazzer
Old Jul 13, 2008 | 11:38 AM
stanging's Avatar
stanging
No I'm not driving them hard, it's just that the center cap tabs get brittle and break off and they don't want to hang on very well with just 1 or 2 tabs holding them.
I've always been careful when taking them off or putting them back on.
Old Jul 13, 2008 | 12:19 PM
Jazzer The Cat
Retired Moderator
So they are plastic [:'(]
If you don't remove them often, put several small dabs of clear silicone adheasive around the cap and glue it on. Several small dabs will easily come off if you gently pry on the cover when changing tires or something. Just be sure the areas are clean and dry before you apply. Just use 3 SMALL dabs at contact points around the cap will hold just fine.
Good luck
Jazzer
Old Jul 13, 2008 | 12:23 PM
stanging's Avatar
stanging
Thanks Jazzer, good thinking.
Tivo304
Aug 28, 2023 12:19 PM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
musnicki
Sep 23, 2015 07:11 AM
Wombatnation
Sep 13, 2015 09:16 PM
96stang3.8
Sep 10, 2015 06:42 AM
