Will these rub up front?
Old 04-17-2011, 08:04 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
It is not uncommon for the front tires to contact the sway bar, but have never seen this with OEM wheels. Is it possible that one wheel is NOT OEM and has a different off-set, so it is more "inset" than the others?
Can you take some pics with a good description of what's being contacted and where?
Jazzer
Jazzer The Cat is offline
Old 04-17-2011, 09:50 PM
Schweino
Schweino's Avatar
Ill get the pics up in the mornin jazz..check back around 11 am
Schweino is offline
Old 04-18-2011, 11:07 AM
Schweino
Schweino's Avatar
So...heres the links for both sides of the sway bar right by the tire.
Driver Side - http://img148.imageshack.us/i/driversideswaybar.jpg/
Passenger Side - http://img189.imageshack.us/i/passengersideswaybar.jpg/
Let me know what you think, cuz its grinded real good into that driver side.
Schweino is offline
Old 04-18-2011, 11:24 AM
Jazzer The Cat
Retired Moderator
My guess is either a bent "A" arm on the rubbing side, or a different wheel on that side with additional off-set/back-space.
Try this.... while the wheels are off, take a measurement of each front wheel. Place the wheel face down on the ground (put it on any surface that wont scratch exposed wheel face). Place a yard-stick across the tire and take a measurement to the surface of wheel where it mounts onto your car (look ***HERE*** for some more info). This measurement should be the same on both wheels.
Jazzer
Old 04-18-2011, 11:34 AM
Schweino
Schweino's Avatar
The front two wheels are the same (American Racing Saleen 240/40 R18). An if I understand tires right (prolly dont) the 265/35 18's for my new AM rims are gonna rub worse then those 240's. Confirm that for me.
I may just pay a diagnostic fee to a frame shop, see if they can tell me im effed or can tell me what needs to happen. Any idea how many labor hours they'd charge? Thanks Jazz, ill mail ya some cookies.
Schweino is offline
winner99
10-01-2015 01:06 PM
winner99
10-01-2015 10:52 AM
mdg
10-01-2015 07:04 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: Will these rub up front?
