a couple questions
Old 04-17-2008, 10:13 PM
m260gt
m260gt's Avatar
Default a couple questions
i have a UPR CAI installed and was wondering if i had to do anything to the filter every once in a while? like take it out and clean it...im thinking it might be the cause of my sucky gas mileage. Also, would changing the plugs and plug wires and fuel filter help it to? i only have 40K miles on it.
Second question. CAMS. throwing around the idea. which ones are the best? and ive seen stange 1,2,3...what are the different stages? and if i get cams would i have to get new heads to go with them?
thanks for all the help!
-Nick
m260gt is offline
Old 04-17-2008, 10:44 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
Default RE: a couple questions
I don't know if UPR's filters are washable. You don't have plug wires, you have individual coils on each spark plug (coil on plug aka COP). And changing them out at 40K isn't needed. Ford calls for them to be changed at 100,000 miles. I put a new fuel filter on every third oil change. And as for cams, use the search function. Talking about cams can be lengthy. There's a lot of information.
96GT226410 is offline
Old 04-17-2008, 10:49 PM
m260gt
m260gt's Avatar
ok thanks for the info. what about fuel injectors? i only get 13mpg babying my car..im just trying to fix it.
m260gt is offline
Old 04-17-2008, 11:01 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
Injectors won't yield better fuel economy.
Tivo304
08-28-2023 12:19 PM
1TUFF302
11-05-2015 04:02 PM
GimpyHSHS
09-18-2015 12:27 PM
04stangman
09-17-2015 01:45 PM
Quick Reply: a couple questions
