thermostat!!!
Old 09-27-2012, 02:48 PM
disposablehero27
disposablehero27's Avatar
Default thermostat!!!
So i put a thermostat in my car. Now shes running hot. I need to know if i can leave the thermo out permanently. ****ty job cause i have to silicone the housing etc etc. Will this damage my engine? It doesnt matter if i dont get heat etc etc. Just tired of fighting this thing and risk over heating
disposablehero27 is offline
Old 09-27-2012, 03:00 PM
jrp1588
jrp1588's Avatar
Something is wrong if you are overheating with a thermostat in. Flushed your radiator recently?
jrp1588 is offline
Old 09-27-2012, 03:05 PM
disposablehero27
This wasnt my question. I realize the thermo is prolly bad. Everything under the hood is brand new and fresh.
Keep in mine i drove 250mi straight with no thermo and it stayed cooler than my old motor with a thermo in it.
Old 09-27-2012, 03:53 PM
Shampue
Shampue's Avatar
Then you answered your own question
Shampue is offline
Old 09-27-2012, 04:55 PM
disposablehero27
Just asking if anyone has had any problems with extended run time with no thermo. Any known problems. Will it damage anything.
Old 09-27-2012, 05:04 PM
jrp1588
jrp1588's Avatar
It'll take the engine longer to reach operating temperature which will suck up some more gas. I've read that without the restriction of the thermostat, there won't be enough water pressure built up, which can lead to localized hotspots. No personal experience running with no thermostat though, just running a lower temp thermostat on my old truck.
jrp1588 is offline
Old 09-27-2012, 07:24 PM
uberstang1
Chupacabra
uberstang1's Avatar
Without a thermo i will just tAke longer to reach temps really, as long as it can reach normal op temps id imagine yur ok. How hot is running hot though?
uberstang1 is offline
Old 09-28-2012, 12:24 AM
dwtjr3
dwtjr3's Avatar
When you put the thermo in did you burp the air bubbles out?
What temp thermostat is it?
The thermostat is not in upside down is it?
Because it shouldnt be overheating with a thermostat in.
dwtjr3 is offline
Old 09-28-2012, 07:13 PM
disposablehero27
its running in the m to a in "normal" pretty warm. It ran fine and just took a few to get to running temp, and always stayed cool. So i'm just going to yank it out and run without it. Just something else to stick or go back and have to worry about later.
Nick Oliver
10-17-2018 04:22 AM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
MusicCity615
09-12-2015 07:05 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Wesley1995
08-30-2015 02:01 PM
Quick Reply: thermostat!!!
