AFR 185cc Heads
Old 05-24-2006, 12:42 PM
88BlueGT
88BlueGT's Avatar
Default RE: AFR 185cc Heads
Not in the office yet.... at 10:30??? Lazy b*tches
88BlueGT is offline
Old 05-24-2006, 02:09 PM
86gt_dominator
86gt_dominator's Avatar
Just got off the phone with AFR they stated that it shouldn't be a problem using the stock pistons but they recommend that I double check of course. Also told me that with the 351W if I decided to spray it or get a blower that the 185's would be the better head to go with. Interesting?????
86gt_dominator is offline
wildcobrar
wildcobrar's Avatar
We are talking stock 351 Windsor engine with the stock pistons right? I ask because I have several here and every 351 W I have pulled apart right from 1974 to 1984 have had a Large rectangular dish in the piston with no valve reliefs because of the depth of the dish in the piston. I point this out because given a .040 inch head gasket and a cam in the 230/240 advertised duration and .560 inch lift range will more than likely work with 2.02 valves. The dish in these pistons is quite deep. I just measured the dish at .125 thous. These are fairly deep and may only need a light massage on the piston to make the heads work if nothing at all.
ORIGINAL: 86gt_dominator
Will the AFR 185cc heads allow for valve clearance with the 351W stock pistons?
[IMG]local://upfiles/38305/F090DD1DB93244C695CA58A1B58BA517.jpg[/IMG]
wildcobrar is offline
Old 05-24-2006, 02:28 PM
86gt_dominator
Yeah a stock 351W. What cam would you use? Just getting as many opinions as possible and researching them all with the manufacturers.
Old 05-24-2006, 02:33 PM
myshifter
I ♥ Acer
myshifter's Avatar
call crane and comp and answer there 15 questions about your car and then they will outline a cam for your needs, just blindly guessing will not yield good results
myshifter is offline
Old 05-24-2006, 02:35 PM
86gt_dominator
good looking out. thanx
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: AFR 185cc Heads
