Which heads?
Old 05-27-2006, 12:45 AM
Grinster24
Grinster24's Avatar
Default Which heads?
I am new to mustangs and looking to buy a nice set of aluminum heads because I know whatever I decide to change on my block the heads will be needed, so they are an important investment. I have heard from numberous friends that the twisted edge heads are the best to buy. But after looking on here for a little while, I have noticed people talking about AFR's? I dont know anything about them and would like to hear peoples experiences or opinions with either of the two.
Grinster24 is offline
Old 05-27-2006, 12:50 AM
boss429
boss429's Avatar
Default RE: Which heads?
AFR;s cost about 400 more than twisted wedge and from my research flow a little bit less.
but some guys seem to really like them
personally id go with the twisted wedge cuz they are nicer on the wallet and i think they should do the trick just as good.
i know when i get enough cash for a set of aluminum heads im going twisted wedge.
ive heard nothing but good things.
boss429 is offline
Old 05-27-2006, 12:57 AM
76stangalang87
76stangalang87's Avatar
I have two friends with AFR's the loved them
76stangalang87 is offline
Old 05-27-2006, 01:02 AM
myshifter
I ♥ Acer
myshifter's Avatar
I used maxed out wedges on a 306, custom grind cam, 11:1 CR if I remember and made 592 spinning it to 7200 or so on the dyno 10 years ago. Mind you the head were max ported. TFS does make a great product and I wouldn't hesitate using them anytime. I used them exlusively on my big blocks and made 900hp N/A until a bunch of other companies started making big ford heads.
myshifter is offline
Old 05-27-2006, 01:31 AM
r.barn
r.barn's Avatar
here's a nice chart that compares all the different heads.
there is also ported stock heads from www.thumperoforangepark.com that flow
about with GT-40X heads @ 215, only $600!!!
r.barn is offline
Old 05-27-2006, 02:23 AM
Grinster24
Grinster24's Avatar
ORIGINAL: r.barn
Sorry I dont know what I'm looking at. I'm pretty much clueless...learning as i'm going along.
Old 05-27-2006, 02:25 AM
myshifter
I ♥ Acer
myshifter's Avatar
ORIGINAL: Grinster24
ORIGINAL: r.barn
In that case then you are a perfect canidate for a set of bolt on Edelbrock RPM's
Old 05-27-2006, 02:29 AM
Trill Gear Head
Trill Gear Head's Avatar
well i'm no expert but if you look at the percentage above stock. The higher the percentage the better. lol i'm just like you, i don't know that much about heads.
Trill Gear Head is offline
Old 05-27-2006, 02:38 AM
Grinster24
Grinster24's Avatar
ORIGINAL: Trill Gear Head
Well it seems like arf 185s seem to give the most airflow which I will need later on.
Old 05-27-2006, 11:30 AM
Mikes Stang
Mikes Stang's Avatar
That chart is VERY nice!!! I've been doing ALOT or research lately for heads. It is nice to see everything in one chart.
Does it seem the Over stock percentage is low for the Power Head? If you look at the Power Head #'s compared to the 40X's, it seems the Power Head #'s are low.
Mikes Stang is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: Which heads?
