intake leak
Old 04-02-2008, 08:08 PM
93 LX FiveO
93 LX FiveO's Avatar
Default intake leak
i got coolant spewing from the lower intake. car runs awesome, but leaks everywhere. is it possible there a cracked water jacket or something like that?
how long does it take to change the lower gaskets?
93 LX FiveO is offline
Old 04-02-2008, 08:17 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: intake leak
leaking out of the corners?? = lower gasket= a few hours of work 3-6 depending on how quick you are
mjr46 is offline
Old 04-02-2008, 08:22 PM
93 LX FiveO
im not that quick, because i over analyze everything but know my way around the 5.0 engine.
if it was the gasket wouldnt it run like crap?
Old 04-02-2008, 08:29 PM
mjr46
mjr46's Avatar
not if the corner gasket is leaking that goes from intake to head port....the coolant ports leaking to the outside at the gasket will not affect the way it runs one bit..only if the gasket were blown at a port where it enters a intake runner and those ports don't house coolant
mjr46 is offline
Old 04-02-2008, 08:30 PM
mjr46
mjr46's Avatar
where exactly is it leaking anyway!!?? pressure test it and you'll know for sure
mjr46 is offline
Old 04-02-2008, 08:35 PM
93 LX FiveO
it actually leaks right around the rear throttle body heater hose.
ive narrowed it down to either the lower intake, or the fitting that hose connects to, which is in the lower anyway.
no room to work so i figure may as well just pull the intake
its not my DD so i got time, but would like to get this done quick
Old 04-03-2008, 10:26 AM
93 LX FiveO
pressure tested it just now, got coolant coming from a couple different places but mostly behind the intake.
too much crap in the way to pinpoint it but the coolant stream is all along the lower intake on the passenger side. drivers side is bone dry.
the leak is coming from the rear somewhere.
my only choice is to drive the car 45 miles to my garage, or leave the intake open for a couple nights in my driveway.
what do u guys think i should do?
Old 04-03-2008, 01:50 PM
brentloftis
brentloftis's Avatar
If it is leaking as bad as it sounds I don't think you will make it more than a mile before having to refill. Can you pull the upper intake off to get a better look at the leak and more hand room?
brentloftis is offline
Vrooom
02-21-2016 05:25 PM
bconboy
09-24-2015 01:55 PM
04stangman
09-17-2015 01:45 PM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: intake leak
