86 Cylinder Heads
Old 06-29-2008, 10:28 PM
87Stallion
87Stallion's Avatar
Default 86 Cylinder Heads
Did 86 5 liters come with E6 or E7 Heads? We tore down a buddies 88 LX to replace the H/C/I. THe heads that were on it were E6's and it has flat top pistons. It looks like the motor came out of a 86 is the reason I ask. We are putting GT40X heads and TFS1 cam in it. THe pistons dont have any valve reliefs so Im worried about PTV clearance.
87Stallion is offline
Old 06-29-2008, 10:36 PM
sultan68
sultan68's Avatar
Default RE: 86 Cylinder Heads
i could be wrong but im pretty sure e7 heads couldn't have been used until 87 and the 86 motors had different heads than the 87 ups
sultan68 is offline
Old 06-29-2008, 10:52 PM
87Stallion
87Stallion's Avatar
THats what I thought but I wanted to make sure I was right.
Old 06-29-2008, 10:58 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
86 motors had no valve reliefs on the pistons and had e6 heads..most likely an 86 motor..casting number on block will confirm it...and only good way to use an aftermarket cam and heads on a 86 block is to use twisted wedge heads
mjr46 is offline
Old 06-29-2008, 11:08 PM
87Stallion
87Stallion's Avatar
THanks mjr. I just hate that weve done all this work to find out its a diff engine.
Old 06-30-2008, 12:38 AM
redpony88
redpony88's Avatar
came with E6 heads, i know this for a fact, i've worked on 2 of them one was a project car i did and the other is 86whitepony's car. if they have a "S" stamped on the pass side bottom front corner, you should be able to see it, i think the E7's had a "T"
redpony88 is offline
Old 06-30-2008, 08:44 AM
86whitepony
86whitepony's Avatar
general rule of thumb e6=GAY. you have 3 options if you want to upgrade heads
1. get the e6's ported
2.buy some trick flows
3. get your pistons notched, then get any head you want
86whitepony is offline
Old 06-30-2008, 08:56 AM
87Stallion
87Stallion's Avatar
Yeah thats what I figured. Im trying to talk him into just buying a new shortblock. Probably be cheaper and better in the long run.
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
Dathan
10-05-2015 05:52 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: 86 Cylinder Heads
