Weird car acceleration
Old 05-20-2009, 10:36 PM
dj1203
dj1203's Avatar
Default Weird car acceleration
When at wot, my car will hesitate and the Tach will kind bounce around shifting randomly between 3k and 4k rpms.... also during this time the car really hits a wall accelerating, if you keep on the gas it will eventually come out of it and continue to climb in rpms. Its really wierd... anyone ever experience this or have any thoughts? it accelerates like normal after 4k and preceding 3k... i tried to take a video of it but quality is not too good.... i hope to try to capture it again here soon so you can see exactly what its doing.
dj1203 is offline
Old 05-21-2009, 12:40 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
you don't figure it is running out of fuel?
TrimDrip is offline
Old 05-21-2009, 10:39 AM
dj1203
dj1203's Avatar
hmm, well idk, i guess thats possible.... idk though cause if i throttle through that same range at higher starting speeds its fine.... how could i check?
dj1203 is offline
Old 05-21-2009, 10:46 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
ah, with your tach bouncing like that, it sounds like it could be something in the fire instead of the fuel. Still you like to take precautions.
The car doesn't give a check light or does it ever flash?
Have you ran the codes?
TrimDrip is offline
Old 05-21-2009, 10:53 AM
dj1203
dj1203's Avatar
The check engine light does work, however it is not indicating a problem. I jsut replaced the hall effect sensor/stator/pickup on the car. Could this be a cause of bad timing? i have it set to 10 degree base time, and i stabbed the distributer with the rotor pointing to the # 1 cylinder @ TDC.
dj1203 is offline
Old 05-21-2009, 04:08 PM
dj1203
dj1203's Avatar
anyone know how to check the timing in a fullproof way?
dj1203 is offline
Old 05-22-2009, 08:18 AM
LCBlackDep183
LCBlackDep183's Avatar
Take out the spout connector, connect timing light to # 1 Dist Wire, Turn on car. Check...
LCBlackDep183 is offline
DrunknRuckus
08-23-2015 10:05 AM
Soldier GT
12
08-20-2015 09:42 AM
antipeterleague
08-18-2015 01:50 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Weird car acceleration
