intake manifold question
Old 07-08-2009, 04:32 PM
  #21
matpat
matpat's Avatar
Default iac valve
what s the iac valve and where is emplacement,
i had to cut a thread from a sensor on my tb because he was to short.i put a new thread but can i cahnge the amp of the sensor
matpat is offline
Old 07-08-2009, 05:22 PM
  #22
kilby94
kilby94's Avatar
Uh... What?
What do you mean thread? Who is he? And why would you want to change the amperage of something?
IAC valve is the Idle Air Control.. It lets air into the engine while the throttle blade is closed. It is the thing that is bolted to the front of your throttle body. A cylinder shaped thingy...
kilby94 is offline
Old 07-08-2009, 05:39 PM
  #23
matpat
matpat's Avatar
Default iac valve
when i put my biger tb I plug my iac valve but the filament of the iac valve was in the way of my tb cable, so i had to cut the connection and i put a longer filament. do this move can have an impact ?
matpat is offline
Old 07-09-2009, 08:11 AM
  #24
kilby94
kilby94's Avatar
I'm not following??
What do you mean filament? So you plugged the IAC valve?
The thing with the gold top on it is the IAC.. If you removed that and plugged the holes, then yes that is a problem..
kilby94 is offline
Old 07-10-2009, 04:34 PM
  #25
matpat
matpat's Avatar
at the beginning the car has a ford 65 mm tb, i put a 75 mm edelbrook.the plug of the iac valve has not the same angle so i need a longer electric wire. i had to cut the wire electric and i put a longer one. can this affect something(amp)
i talk about my switch of 24 lbs injector to some guy that work in speed shop and they all say that it s impossible that the car take this switch with out a chip, new module or to enter in the computer to send the new information.
matpat is offline
Old 07-10-2009, 04:55 PM
  #26
kilby94
kilby94's Avatar
I have never heard of anyone that changed the throttle body and had to extend the wiring harness to the IAC.. Something ain't right with that.. You could have manipulated the wiring harness a little bit for some extra length.. The proper way to install 24# injectors would be to have a chip burnt to change the parameters in the ECM.. But a common way, that works, is to change out the mass air flow to one that is calibrated for 24# injectors.. That will then trick the computer and will work just fine.. With the car running unplug the IAC and see if that changes the way it idles.. If it doesn't change anything, that is a problem....
kilby94 is offline
Old 07-10-2009, 05:02 PM
  #27
kilby94
kilby94's Avatar
Also never run your car with the MAF unplugged...
kilby94 is offline
Old 07-10-2009, 06:15 PM
  #28
matpat
matpat's Avatar
the maf will transmit that there is more air that is coming but how my computer will know that i put 24 lbs?
engine with out iac and maf the idle is at 800 rpm
engine with iac but not maf the idle is at 800 rpm
engine with iac and maf the idle is at 1500rpm
i can unplug my iac valve and there is no difference to the idle
matpat is offline
Old 07-11-2009, 05:17 PM
  #29
kilby94
kilby94's Avatar
A MAF that is "calibrated" for a certain injector and will send a different voltage value to the ECM so that the ECM will send the right signal to the injector to have the correct pulse length. The injector pulse length is different between two different # injectors..
NEVER RUN YOUR ENGINE WITH MAF UNPLUGGED....
Leave the MAF and IAC hooked up.. Crank the car.. Unplug the IAC.. Did the idle change?
If not then something is not working with the IAC.. Either its bad, needs a cleaning, or your wiring is FUBAR..
Take the IAC off and spray some carb cleaner inside of it and try to clean out as much gunk as you can (if any)... Try it again.. Report back!!
Have you ran a self test diagnostic for codes yet?
kilby94 is offline
Old 07-11-2009, 08:21 PM
  #30
matpat
matpat's Avatar
Default remenber something
sorry if i have many question lol. when i buy my gasket that goes between my spacer and my intake there were not identic. there is a little slot on the intake just down the 75 mm hole. on the new gasket,this little slot was not there and on my old one there were one.
matpat is offline
Tivo304
08-28-2023 12:19 PM
Luke9222
10-22-2015 11:55 PM
Mustangmalo
09-06-2015 05:22 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: intake manifold question
