Need water pump help
Old 06-14-2010, 12:56 AM
87 ttop stang
87 ttop stang's Avatar
Default Need water pump help
Once again I need your guys help. I have an 87 stock 5.0 I put in a new water pump because the old one's gasket blew. I put the new one in and coated the gasket front and back with permetex and cleaned the crap out of the timing chain cover it was really smooth. Also I belive I had the gasket lined up perfectly. I drove the car for about an hour everything was fine and boom the new gasket also went. Should I have waited 24hrs to let it cure or does it really matter? And also does anyone know what the torque settings is for the pump bolts are. What have I done wrong? Any help would be greatly appriciated. Thanks.
87 ttop stang is offline
Old 06-14-2010, 06:04 AM
AdderMk2
Banned
AdderMk2's Avatar
which "permatex" did you use. and I always let them cure (on my cars)
AdderMk2 is offline
Old 06-14-2010, 11:10 AM
Bubba 95SN
Bubba 95SN's Avatar
Did you clean the crap out of water pump? Torque is 12-18 foot pounds. Just small piece of old gasket will ruin your day. Mark where it is leaking and check the area closely when you get it apart.
Bubba 95SN is offline
Old 06-14-2010, 01:03 PM
87 ttop stang
Thanks guys
Old 06-14-2010, 01:15 PM
mustangfever_94
mustangfever_94's Avatar
I have nevered used permatex. I always use automotive schlack and the gasket that comes with the water pump. I've never experienced a single problem using this method my 91,92 & 94 mustangs.
mustangfever_94 is offline
Old 06-17-2010, 03:11 PM
87 ttop stang
Thanks for all your guys help.
Old 06-18-2010, 06:55 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
I copper coat my water pump gaskets that come with the pump. Works ever time.
projectresto83 is offline
Old 06-18-2010, 12:17 PM
Jfsram
Jfsram's Avatar
Is the gasket on backwards. It doesn' look much different when reversed.
Also is the timing cover in good condition. I've seen them rot from the inside out. Making the sealing surface pretty thin.
Jfsram is offline
jwog666
12-27-2021 08:09 PM
jerrytubes
10-23-2015 12:11 PM
Bokeo
10-10-2015 08:28 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
Quick Reply: Need water pump help
