Fuel pump problem?
Old 01-04-2011, 09:36 PM
dreamer1uk
dreamer1uk's Avatar
Originally Posted by chilywily72
At first i thought it was normal but my fuel pump whines pretty good sitting idling its pretty loud and running down the road you can still hear it pretty well and it never shuts off is this normal or do i have a bad relay or something?
You could do several fuel pressure test to make sure you have the correct fuel pressure. Also, you can do an amp draw test too on the pump and compare them with factory specs. That will give you an idea of how well the pump is performing against the OEM specs.
dreamer1uk is offline
Old 01-05-2011, 12:50 AM
drewsky121
drewsky121's Avatar
hey if it is whining after you shut it off.. its a bad relay. just replaced mine about a month ago, wouldn't shut off till i disconnected the battery or waited for an hour.. get a new relay and it'll help
drewsky121 is offline
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
cbird1177711
09-02-2015 08:51 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: Fuel pump problem?
