knocking noise from back of motor
Old 06-24-2011, 04:28 PM
slo302
slo302's Avatar
Default knocking noise from back of motor
this is my situation i have a 89 mustang with a rebulit 302. stock block gt40 p heads new rods lifters b303 cam bbk headers and 24lb injectors and biog mass sensor and 70mm throttle body. my problem is i have a knock in my motor that sounds like its coming from the back i torn the motor down took out my lifters and everything and can still hear noise when cranking it. any suggestions to what it mihgt be some one told me the flywheel might be loose or along that lines
slo302 is offline
Old 06-24-2011, 06:08 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
That is possible. You will know that if you take the starter off and try and move the flywheel.
projectresto83 is offline
Old 06-24-2011, 07:35 PM
Bubba 95SN
Bubba 95SN's Avatar
Rev motor up to 2500rpm let off gas.Knock knock on deceleration is a loose flywheel.
Bubba 95SN is offline
Old 06-25-2011, 09:51 AM
slo302
slo302's Avatar
thanks guys ill try that today let u know if thats the case
slo302 is offline
Old 06-25-2011, 11:00 AM
AdderMk2
Banned
AdderMk2's Avatar
OR... he could just take the starter out and try to wiggle the flywheel....
OR... he could unbolt the bottom part of the block plate, and try to wiggle the flywheel...
OR... he could use a pry bar from the clutch fork hole.... to try to wiggle the flywheel...
basically, don't run the car anymore. You can be causing serious damage to the crank and/or flywheel.
AdderMk2 is offline
Old 06-25-2011, 11:03 AM
projectresto83
M.A.D. Motorsports
+ he did say he tore down the motor....
anyway, there are a few suggestions so lets see what happens
Old 06-26-2011, 12:07 AM
slo302
slo302's Avatar
thanks everyone put a new fly wheel on and new clutch why not while i was there car sounds great now
slo302 is offline
Old 06-26-2011, 01:09 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
good deal. so what was it making the noise?
TrimDrip is offline
djbigskrilla
09-20-2022 01:04 AM
msavoia23
12
07-07-2018 12:08 PM
HorsePower99
08-26-2015 11:29 PM
HorsePower99
08-26-2015 08:32 PM
91StangOwner
08-20-2015 11:34 PM
Quick Reply: knocking noise from back of motor
