New to a mustang
Old 06-03-2012, 02:27 PM
Katy Fincannon
Katy Fincannon's Avatar
Default New to a mustang
I just bought my first mustang. It's a 1990 Mustang Cobra GT fox body style. my headlights dont work on dim my running tail lights work jut not my brake lights. and when my battery is left hooked up it drains it. any ideas? Also when in OD it wants to rev up high rpms at about 45 mph and not go any faster.
Katy Fincannon is offline
Old 06-04-2012, 08:05 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Well, welcome Katie, sorry your new purchase is giving you problems. Your headlights not working could be your hi/low switch, wiring connections, or check the bulbs themselves,
For your brake lights, crawl under dash by your brake pedal, you will see a little switch that moves when you step on pedal, make sure wires are connected and switch is adjusted.
Actually, never mind, those are your small problems. Sounds like your tranny is junk, check your fliud. If it has a burnt smell to it, and not bright red, find a good, reputable tranny shop check it out. Sorry. Good luck.
88 orangepeel notch is offline
Old 06-04-2012, 08:46 PM
Bubba 95SN
Bubba 95SN's Avatar
You from the great white north? U.S. did not make a Cobra in 1990.
Bubba 95SN is offline
Old 06-05-2012, 04:03 AM
Katy Fincannon
I live in ga and the title itself says cobra gt on it. idk. but I got the lights to work finally every bulb was blown... weird. but the popping in the rear end was the wheels were loose. but still having issue with battery draining really quick and the transmission not wanting to work right. The tranny fluid is that bright red color and smells like normal tranny fluid.
Old 06-05-2012, 07:23 AM
Tony71502
Tony71502's Avatar
If the RPM climbs and the speed stays the same. Sounds like the clutch is worn out. When the power from the engine overcomes the clutch's ability to grab the flywheel... then the RPM's go up and the tranny doesn't go anywhere.
Wait... is this an auto or standard?
Cobra came out in 93'. You have a regular GT.
Tony71502 is offline
Old 06-05-2012, 09:58 AM
Katy Fincannon
I have an automatic. and ok I was just going with what the title said it was.
Old 06-05-2012, 10:39 AM
Tony71502
Tony71502's Avatar
If it's revving up and not increasing speed then your torque converter or tranny has an issue. My money is on torque converter.
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
chain
08-17-2015 08:52 AM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: New to a mustang
