autometer coolant temp gauge
Old 06-10-2012, 10:23 AM
dillon1340
dillon1340's Avatar
Default autometer coolant temp gauge
My gauge reads 20 degrees lower than what I measure with my infrared thermometer at the sender (the reason I was checking was because I just couldn't believe the car was running that cool after an hour's driving). The gauge worked fine for years so I assumed the sender had failed and replaced it. Made sure the sender was getting coolant flow too, but still it reads 20 degrees low, so I made sure I had ordered correct sender and ordered and installed a second new one with no luck. Is it possible the gauge is bad? I hate to spend the money on new gauge only to find out I have same issue and missed something simple.
dillon1340 is offline
Old 06-10-2012, 12:29 PM
mustangGT86_05
mustangGT86_05's Avatar
I would try cleaning up the connections and see if that helps
mustangGT86_05 is offline
Old 06-10-2012, 12:50 PM
mustangGT86_05
Ugh hit the wrong button and accidently double posted, can't seem to delete it
Old 06-10-2012, 07:06 PM
dillon1340
dillon1340's Avatar
tried cleaning up the connection. and made sure it had solid ground wire but still same problem. I think I'll probably just buy the new gauge.
jwog666
12-27-2021 08:09 PM
wraith777
09-28-2015 10:49 AM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: autometer coolant temp gauge
