Running Hot
Running Hot
I have a 67 with a 289, 2 bbl.It hasbeen heating up way fast even when the outside temperture is 28 degrees. I'll drive around the block and the radiator will be way hot, sometimes if i drive it for a while it will pop the cap and boil over. I just replaced the water pump today and it still heats up fast. I replaced the thermostat a few months ago. Radiator looks like its not clogged. Any ideas or suggestions on what to do, or whats wrong with it?
Running Hot
yea i'd start by checking to see if your leaking anywhere. then check your hoses, and look at your coolant and see if it's an abnormal color. then check for compression. there's a million reasons why your car could overheat like that. water pump, heater core, head gasket, bad hose etc.....ive got a leak right now. a tiny hole in my intake manifold is allowing just a teeny bit of coolant to ooze out.
Running Hot
Originally Posted by BCisme
yea i'd start by checking to see if your leaking anywhere. then check your hoses, and look at your coolant and see if it's an abnormal color. then check for compression. there's a million reasons why your car could overheat like that. water pump, heater core, head gasket, bad hose etc..... ive got a leak right now. a tiny hole in my intake manifold is allowing just a teeny bit of coolant to ooze out.
Running Hot
Ithought it might be the head gasket, but the coolant looks very clean, no smoke in exhaust, and oil looks clean. I'm thinkin it might be a bad thermostat even though its new, but I don't know. The last thing I wanna do is change a head gasket.
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
