Running a tune with stock intake.
Old Apr 4, 2007 | 11:05 PM
Burnsy's Avatar
Burnsy
Default RE: Running a tune with stock intake.
ORIGINAL: howarmat
Yes you can get them used. I wouldnt do it unless you like spending money. buy an tuner for 250 used lets say....then add brenspeed tunes @ 125 or B ama tunes @ 180. You are now at the same cost or more for the tuner if you bought it new! and you still need to find an intake for under 300 to just stay below 700 which is still more than most combo are for new!
tuche
Old Apr 4, 2007 | 11:08 PM
bluene05GT's Avatar
bluene05GT
You're A/F ratio and timing will probably be off - not good.
Old Apr 4, 2007 | 11:14 PM
howarmat's Avatar
howarmat
s197 Junkie
They will not be off because the tune is written for the stock intake and whatever octane he uses.....the whole point of using the tuner is to correct the a/f ratio adn change the timing to get more HP, amongst other things.
Old Apr 4, 2007 | 11:24 PM
Bluestar's Avatar
Bluestar
Don't fool around with a used tuner, be patient, when you have the funds get the CAI/Tuner combo from the tuner of your choice. Trust us it'll be worth the wait.
Old Apr 5, 2007 | 12:20 AM
hammeron's Avatar
hammeron
this may be hard to believe but, the most gains would
come from simply dropping in a K & N air filter
(or equivelent).
http://www.users.qwest.net/~cookpaging/coldairdyno.pdf
if you look at these dyno results, you will see that just the air
filter alone, took the stock GT from:
261hp / 281tq to
274hp / 292tq
getting the jlt + tune gets you up to:
286hp / 302tq
Edited to correct air filter #'s - Thanks Howarmat good eye!
ORIGINAL: acascianelli
I'm going start modding my Mustang. I wanted to buy a tuner first and flash to a 93Octane tune. Would it be safe to run a 93Octane tune with the stock intake? I will eventually buy an intake also, but I want to use the parts I buy right away.
Old Apr 5, 2007 | 12:26 AM
howarmat's Avatar
howarmat
s197 Junkie
ORIGINAL: hammeron
(or equivelent).
261hp / 281tq to
278hp / 295tq
286hp / 302tq
That is not an air filter that is K&N version of a CAI
msavoia23
12
Jul 7, 2018 12:08 PM
drfister
May 3, 2018 10:38 PM
spectreman
Mar 31, 2016 09:26 PM
'stangdude
Aug 12, 2015 01:27 PM
Jacob4589
Aug 8, 2015 11:00 AM
