Cams
Old Apr 30, 2007 | 11:20 PM
  #31
MusiccityGT's Avatar
MusiccityGT
Default RE: Cams
Hmmm... Young no nothings wasting money on cams for the 3v which make no power...
Let's see, I am 44 years old, got 40 h/p with my cam change, and am far from a novice when it comes to performance mods.
I disagree with your assesment sir.
Old Apr 30, 2007 | 11:22 PM
  #32
androdz's Avatar
androdz
I ♥ Acer
Default RE: Cams
Comp camps stage 3 are really MILD cams go with stage 4 or with another company. They are really pathetic, just read what brent thought after the install.
Andrew
  #33
MusiccityGT
Default RE: Cams
ORIGINAL: DeStonn
I just think it is the brand of cams because my tuner is AWESOME (Adamfrom STMotorsports) I might have to break down and get the Comp stage 3 cams.
Well, I wasn't going to go there, but yea, BBR's are regrinds made to sound good, but thats about itand I have seen no real world numbers, only their exaggerated numbers.
Old Apr 30, 2007 | 11:23 PM
  #34
DeStonn's Avatar
DeStonn
Default RE: Cams
ORIGINAL: MusiccityGT
What cams are you using and what other mods along with them
Old Apr 30, 2007 | 11:25 PM
  #35
DeStonn's Avatar
DeStonn
Default RE: Cams
Can people running cams please chime in on what cams they are running
  #36
MusiccityGT
Default RE: Cams
ORIGINAL: androdz
Andrew
I am happy with the 40 hp from my pathetic cams.
Old Apr 30, 2007 | 11:28 PM
  #37
MusiccityGT
Default RE: Cams
ORIGINAL: DeStonn
The "pathetic" Comp stage III and beehives. See my mods under the sig pic.
Old Apr 30, 2007 | 11:33 PM
  #38
DeStonn's Avatar
DeStonn
Default RE: Cams
You have a bunch of mods. I will have my tuner run through it again when I do the driveshaft and other mods and see if he can change some things.
Old Apr 30, 2007 | 11:41 PM
  #39
androdz's Avatar
androdz
I ♥ Acer
Default RE: Cams
Lol Man they are really pathetic nothing personal they are really mild. I mean 40hp from cams from a stage 3 on a 4.6L engine is rather low since they are mild. They should be stage 1, just compare the lift/duration to other makes
Look Comp Cams Stage 1 Lift in.480/ex.470 Duration in-253/ex270 Comp Cams Stage 3 Lift in.490/ex.480 Duration in261/ex278 Crane Cams Stage 1 Lift 468/516 Duration 256/272 Crane Cams Stage 3 Lift 528/576 Duration 276/292 Crower Cams Stage 1 Lift 480/468 Duration 262/278 Crower Cams Stage 3 Lift 490/502 Duration 278-294
Old Apr 30, 2007 | 11:42 PM
  #40
MusiccityGT
Default RE: Cams
ORIGINAL: DeStonn
LOL... Yea, and still going! Have him look at the timing curve. You should be getting in the 28 to 29 degrees total timing range between the global and advance curves.
