Fuel filter replace..result PICS !!!
Old Sep 13, 2007 | 07:44 AM
  #21
GidyupGo's Avatar
GidyupGo
Default RE: Fuel filter replace..result PICS !!!
ORIGINAL: Eleanor06
I don't know? From all these gas/fuel threads shell has been held high by others.I'll stay running shell
for another 10,000 and do a early change on the filter and see if I get the same results.
It is good gas. Maybe the best. The pictures indicate an improperly mantained tank and/or filter at the pump.
Old Sep 13, 2007 | 09:58 AM
  #22
ANBAUTO's Avatar
ANBAUTO
wow that does look wierd, when i changed mine at 15k miles it was clear as day
Old Sep 13, 2007 | 09:59 AM
  #23
ohnoesaz's Avatar
ohnoesaz
ORIGINAL: GidyupGo
ORIGINAL: Eleanor06
Im not sure how a tank can be improperly maintained?
Old Sep 13, 2007 | 10:11 AM
  #24
bchataroo's Avatar
bchataroo
Hey people,
Do you realize that all of the refineries produce gasoline from the same specs. They also send it to the East coast through one pipeline. (yeah, they just meter how much they put in and take out)
Shell employee
Old Sep 13, 2007 | 10:40 AM
  #25
GidyupGo's Avatar
GidyupGo
ORIGINAL: ohnoesaz
ORIGINAL: GidyupGo
ORIGINAL: Eleanor06
Well, you get your standard size back hoe,......need I continue?I said and/or Mr Loctite.
Old Sep 13, 2007 | 10:42 AM
  #26
GidyupGo's Avatar
GidyupGo
ORIGINAL: bchataroo
Hey people,
Shell employee
I'm sure we do. Only difference is the additives.
Old Sep 13, 2007 | 10:52 AM
  #27
Burnsy's Avatar
Burnsy
ha! forgot about that
Old Sep 13, 2007 | 11:02 AM
  #28
GidyupGo's Avatar
GidyupGo
ORIGINAL: Burnsy
Yea, that one should be a sticky.
Old Sep 13, 2007 | 12:02 PM
  #29
MartyMoose's Avatar
MartyMoose
ORIGINAL: GidyupGo
ORIGINAL: ohnoesaz
ORIGINAL: GidyupGo
ORIGINAL: Eleanor06
At first glance I too thought you were suggesting "improperly maintained"car gas tank (versus the station's tank).[&:]
Old Sep 13, 2007 | 12:09 PM
  #30
MrSandman's Avatar
MrSandman
All teh big brands are fine.. it's the local/regional stations. BP in MI and OH is **** because of who owns the stations.. Cities were the oil companies are in control of the stations.. and not a privite owner with a particular branding.. are more predictable.
If you find a clean privately owned station and have no problems.. stick with them (good to support the "little guy").
BP and Shell put a lot of additives in their gas.. and are equally as good on paper. If a tanker rolls up and pours that gas into an old rusty tank that's 30 years old... the brand isn't the problem.
Just buy the gas at a newer, clean station and you should be fine.
ORIGINAL: mygt500
Hey stick with the BP gas from now on IMHO. Friend got bad gas from Shell and lost 3 injectors and the fuel lines and filter needed to be chenged as well. Cost big money and warranty did not cover it (long story). Just an FYI.....I will never buy shell....but others swear by it!
ORIGINAL: Eleanor06
Oct 26, 2015 05:01 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Wombatnation
Sep 13, 2015 09:16 PM
tramphardrocker
Sep 13, 2015 08:56 PM
5.0 kevo
Sep 3, 2015 06:24 PM
