WATER TEMP GAUGE
Old Aug 25, 2008 | 08:05 AM
  #31
Caution's Avatar
Caution
+1 Thats where mine is
Originally Posted by MTAS
I put the sending unit in the plug on the driver's side of the block, beneath the exhaust manifold. It's a small brass plug threaded into the block. Make sure you have whatever you're putting in there ready to go as soon as you remove the factory plug! When that plug comes out, you'll only lose about 8oz or so of coolant, but it's all at once Don't forget the little copper crush ring or it will leak - I know this from personal experience
Old Aug 26, 2008 | 12:10 PM
  #32
95PreludeSi's Avatar
95PreludeSi
Did sender thread in properly, or did you need some adapter. If so, which one?
Old Oct 28, 2008 | 12:44 AM
  #33
doode's Avatar
doode
bump from the dead
but how did you guys break that plug loose?
i see red lock tite on that and the sucker isnt coming out ...i tried for 10+ mins
Old Oct 31, 2008 | 12:24 AM
  #34
bigbadbenw777's Avatar
bigbadbenw777
hey i have a gauge cluster for a 65 mustang and nothing is attached, i do not know how to set up gauges???/ where should i start??
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
