window movement when opening door
Old Dec 9, 2007 | 10:28 AM
  #21
MrSandman's Avatar
MrSandman
Default RE: window movement when opening door
Old Dec 9, 2007 | 10:29 AM
  #22
VerginaStang's Avatar
VerginaStang
This happened to me the other day... the drivers side window wouldnt fall when I was trying to open it. sucked *****. Luckily the passenger side door would open, so I started the car, blasted the defroster, and went back in the house
Im a little worried now though... what if both doors freeze [:@]
Old Dec 9, 2007 | 10:31 AM
  #23
TPony's Avatar
TPony
Good point, you all, never thought of that one...
Old Dec 9, 2007 | 10:48 AM
  #24
Pwny's Avatar
Pwny
My battery died, and as a result the window lowering function needs to be recalibrated. In other words, you have to reset the program when the battery is disconnected for a length of time. On the other hand, no problems whatsoever.
  #25
S197_GTvert's Avatar
S197_GTvert
+1 on the no TSB so u should be good to go and if you are really conserned buy a beater car for the winter all u need is heat and radio
Old Dec 9, 2007 | 12:39 PM
  #26
owero01's Avatar
owero01
Never had that problem.
Old Dec 9, 2007 | 01:39 PM
  #27
Bluestar's Avatar
Bluestar
Tpony, when I opened the door look what came out.....
Old Feb 11, 2008 | 10:40 PM
  #28
zoomer's Avatar
zoomer
I also have had problems with the window seal in winter but mine is worst cause mines a 2005 convertible. The winter came ,the window froze .wouldnt move down a lil like it should and when I went to open the door it raunched its way past my convertible roof . I almost died. The convertible roof usually hangs over the window when door is closed. I was so scared to force it by my rag top again I left it parked till better weather came and I drove my van instead. I see it as a design flaw by ford. Some ideas i had to fix it is to buy a remote car starter and prewarm the car before opening the window/door.And I plan to move into a new place that at least has a carport or garage.
Old Feb 11, 2008 | 11:51 PM
  #29
doode's Avatar
doode
after mywindowsfroze on me, when i have to park the car outside i drop the windows 1/4"...
low enough to clear the weather stripping, high enough to keep the snow out
ive had to do it a few problems and never hada problem
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
Sep 25, 2015 06:58 PM
